headers and engine swap
Old 07-12-2014, 10:12 PM
99rangerdan's Avatar
99rangerdan
99rangerdan is offline
I am putting a 4.6 out of a 95 crown police in my 67 f100 I am looking to put headers on it but am not sure about the flange some look like the bolt location moves and do I need the egr or can I eliminate it I am shaping the whole harness and Trans as well any help would be great thanks
Old 07-24-2014, 03:19 PM
badranger34's Avatar
badranger34
badranger34 is offline
Are you looking to purchase headers, or make your own? I believe all 4.6L engines use the same flange design. When I fabbed up headers for my 4.6 DOHC, I purchased some flanges off ebay.
As far as EGR, you can just block it off. I am doing the same thing with my swap, however I will be using a tuner to eliminate the EGR function as well; so my CEL doesnt come on.
Old 07-25-2014, 07:51 PM
99rangerdan
I am looking at buying a set just need to check the clearance i have vs mustang or f150 to see which style will work best hoping someone has tried and had brand and or style suggestions thanks for the feed back
307-Niner
12-23-2022 11:01 AM
TheGageinator
01-30-2014 05:09 PM
rodster150
1997 - 2003 F150
12-22-2009 08:50 PM
David6349
1978 - 1996 Big Bronco
03-17-2003 04:06 AM
Black_Bronco
09-09-2002 10:00 PM
Quick Reply: headers and engine swap
