crew cab owners
Old Mar 12, 2007 | 07:09 PM
scottddove's Avatar
scottddove
crew cab owners
I just found out you can put power windows in the rear door by simply using regulators out of a donor truck or bronco from the front doors. It isn't easy but I did it and it works great. I need to get it all wired up and still need to find some flat switches that will work but thought I would pass this modification along.
Old Mar 13, 2007 | 09:21 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Please post pictures when done, I want to do the same thing to mine.
Old Apr 29, 2007 | 08:34 AM
scottddove's Avatar
scottddove
got the power windows and door locks done. I have put some pics in my gallery if anyone is interested. Also just put on some new tires and wheels, mounted them myself by hand that was a job. what do you think??
Old Apr 29, 2007 | 06:51 PM
Sycostang67's Avatar
Sycostang67
Looks good, are those the original door handles on the back doors, they look like the same ones in my Capri. Also curious about your PW swithces, are those ford switches? I am adding PW/PL from a 1990 truck and I am trying to use the 90 switches on my 85 door panels.
Old Apr 29, 2007 | 07:51 PM
scottddove's Avatar
scottddove
Sycostang those rear door handles are original and as for the switches they are actually a switch I picked up at the help section at the autozone. they are gm and I had to get the part that actually hooks to the switch off a lumana at the junkyard. They were the only flat switches I could find that were flat and had a 4 switch set up.
