Well the set I was looking at is only a 7 piece. But apparently there are other types of "tamper" bits available.
Originally Posted by Example
Product Description:
Security Bits Set contains many of the most common tamper proof type security bit sizes, including: tri-wing bits,
torx bits,
spanner bits,
and hex bits.
My MAF uses the normal TORX and IIRC the basic set I had included the correct small size
FWIW... I always by Torx sets with the hole in the center for the tamper proof pin
That said... I still have sets with no hole and most of the time if I run across a torx bolt with the pin and my bit is "normal" no hole I just break off the pin by wiggling back and forth with a jewelers screwdriver or other small implement
