Shutter or Vibration is it NORMAL?
Old Mar 12, 2007 | 10:58 AM
HTTTRH's Avatar
HTTTRH
Question Shutter or Vibration is it NORMAL?
I always search before I post and didnt find much so my question is....I am fairly new to Ford Diesels I have an 04 PSD CC 4x4 F250. Occasionally I will have to get on it a tad and when I do it seems to vibrate or shutter thru or to the rear of the truck. Is this normal? It doesnt feel like smooth acceleration. I have proper tire air pressure, perfect alignment, all maint. complete. Dont know if this is nature of the beast or what.
BONUS QUESTION, How often should I repack wheel bearings or how can I tell there are in need? Thanks everyone!
Old Mar 12, 2007 | 11:07 AM
hott-rodd's Avatar
hott-rodd
I think this will help you.
https://www.ford-trucks.com/forums/5...feel-like.html
Old Mar 12, 2007 | 11:35 AM
Enomra's Avatar
Enomra
There is a TSB on this. It is a drive line vibation and the spacers will fix it.
Old Mar 12, 2007 | 12:31 PM
HTTTRH's Avatar
HTTTRH
hott-rod if it is an injector problem is it covered under warranty since it is internal? I have less than 100k miles on the truck. thanks
PS ANy info on the wheel bearings. thanks
Originally Posted by hott-rodd
Old Mar 12, 2007 | 12:33 PM
HTTTRH's Avatar
HTTTRH
Is there a link to the TSB so I can read it? THanks
Old Mar 12, 2007 | 12:47 PM
hott-rodd's Avatar
hott-rodd
Should be, seems the 6.0 has has many injector issues covered.
Old Mar 12, 2007 | 02:05 PM
HTTTRH's Avatar
HTTTRH
ps The shudder or vibration happens when I am coming out of a stop.Such as a stop light...hit the gas shudders up to desired speed and then levels off to a smoother ride. Thanks again
Old Mar 12, 2007 | 02:23 PM
Enomra's Avatar
Enomra
Yes this is the same as I experienced and I fixed it with the spacers. I can't seem to find a link to the TSB. But if your under warranty you service dept will know about it and should be an easy fix. I'm guessing you have the short bed as they are more prone to this than the long wheel base. It all has to do with the drive line angle. I put a 4" lift on my 2003 and it needed 3 spacers to remove the vibration during take off.
Old Mar 12, 2007 | 04:44 PM
hott-rodd's Avatar
hott-rodd
Don't sound like the injector shudder, which happens mostly at throttle tip in.
Old Mar 12, 2007 | 04:57 PM
Skoiv's Avatar
Skoiv
Go to the Recalls/TSB tab at the top of the web page. Look at tsb# 05-17-6. I just made an appointment to get mine fixed. It does the same shudder starting out from a stop and then it goes away pretty quickly. If I take off real slow it won't do it.
Old Mar 12, 2007 | 05:09 PM
OZX1's Avatar
OZX1
I looked and found this... I know there's another one out these somewhere that has other techniques. I'll look some more.
Shudder on Acceleration:
On trucks with single driveshafts, check the rear axle spacers. If the spacers are installed with the thin side (1 7/8") facing forward, they should be reversed (swapped left to right) so the wide side (2 1/4") faces forward. If the truck now only shudders with a load, swap out the spacers with 2" flat ones from an F250 long wheel base (two-piece driveshaft), P/N 2C3Z-5598-PA.
Old Mar 12, 2007 | 05:52 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
I was told by my dealer there was no lube points on the 4X4 front end as this was all sealed. Change the front axle lube per book though.
Old Mar 12, 2007 | 09:28 PM
Super08's Avatar
Super08
He has a crewcab. Here is a link for the TSB to shim the carrier bearing...
https://www.ford-trucks.com/tsb/full...hp?tsb=05-17-6
Old Mar 12, 2007 | 09:32 PM
OZX1's Avatar
OZX1
Yup! That's the one I was thinking about. Well done, Super08!
Old Mar 12, 2007 | 10:55 PM
HTTTRH's Avatar
HTTTRH
Thank You All!!!
