Loosing Oil
Old Mar 11, 2007 | 11:34 PM
'99 STROKE's Avatar
'99 STROKE
Loosing Oil
Hi guy's, I've been reading and learning alot on this site. All for starting mods. BUT my 99 stock truck says otherwise! One thing I know is listen to the truck. Now down to the problem. I have read the thread Zwalter has had problems fixing. The difference I have is, all I have to do is add oil to the engine and it will start. The oil seems to be coming out from the top of the engine and dripping dripping down by the starter. I also noticed a puddle of oil on top of the motor . I'm very thankful for all the knowledge you guys have given me and hope you can help me.
Old Mar 12, 2007 | 06:27 AM
Uzumati's Avatar
Uzumati
Check the turbo pedestal closely. Spray down with degreaser and rinse and then crank it up and see if you can locate it.
Old Mar 12, 2007 | 10:05 AM
HeatStroked's Avatar
HeatStroked
Check the HPOP lines. "O" rings can blow out.
Old Mar 12, 2007 | 06:52 PM
'99 STROKE's Avatar
'99 STROKE
Well my wife took the truck to her mechanic today. Over the phone he thought it was a oil pressure switch thenafter looking he thought high pressure oil line. Next now it's the high pressure pump. All this info. was free so now I'm wondering how hard this is to change myself. And if anyone knows of a good place to get one at areasonable price. He said $700. I would appreciate any insight you guys can give me.
Old Mar 12, 2007 | 07:14 PM
Uzumati's Avatar
Uzumati
Is that 700 including labor?
heres just the pump http://www.dieselsite.com/index.asp?...ROD&ProdID=472
Old Mar 12, 2007 | 07:20 PM
'99 STROKE's Avatar
'99 STROKE
No thats parts only.
Old Mar 12, 2007 | 07:34 PM
Uzumati's Avatar
Uzumati
Its not that bad of a R&R and you could save a bit of money. The price in that link is with the 150 core that you get back. PM me your email address and I'll send you the procedure.
Old Mar 12, 2007 | 10:22 PM
'99 STROKE's Avatar
'99 STROKE
Amiller93I sent you a PM hope to get that info. Hopefully can get to changing that soon. Thanks for the help.
Old Mar 12, 2007 | 11:12 PM
HeatStroked
IMO, probably just the HPOP line "O" ring and they're sticking you for a pump.
Old Mar 13, 2007 | 05:51 AM
'99 STROKE's Avatar
'99 STROKE
How can i check that?
Old Mar 13, 2007 | 06:59 AM
'99 STROKE's Avatar
'99 STROKE
The guy that looked at this tried to replace the switch and said it just popped out and sprayed oil all over. Does this mean the pump is working and is blocked somewhere?
Old Mar 13, 2007 | 10:41 PM
'99 STROKE's Avatar
'99 STROKE
O.k I stand corrected! the true problem isnt that the HPOP is gone. It is that one of the line has been loose and apparently stripped the threads en the pump over time. So now I have a good pump with bad threads on one line.
Old Mar 13, 2007 | 10:46 PM
'99 STROKE's Avatar
'99 STROKE
HeatStroked, the o-ring factor was in play until the end. But it's not over yet? It was kinda the o-rings just not the way I hoped for.
F250_
17
Feb 12, 2015 09:46 AM
Gary A.
Jul 20, 2014 09:19 PM
JustinRo2014F250
6.7L Power Stroke Diesel
15
Apr 2, 2014 08:47 PM
xfordman
May 15, 2006 05:54 PM
2ndmouse
23
Aug 10, 2004 11:21 PM
