marbles in converter
I looked up all ways in the search about the marble noises in the converter. I for some reason remember a cure to the noise without replacing the converter. I am presently trying to trade the old girl in and not one dealer wants the truck with all that noise or they offer a very low price with the response they have to replace the transmission. Any input would be greatly appreciated.
The noise is in the converter because it goes away as you go off idle rpm . The Ford dealer checked the flex plate and bolts and said they were ok (without taking out the trans.) I thought there was some switch or bypass that eliminated the chatter at idle with these trans. I forgot this is a early 99 f250 sd cc 4wd psd
You can throw a new converter in for $1000.00 but it would probably not raise the trade in price..
Probably best to just take the best offer and run...
dont think friction add. will do anything, from what iv been told that noise is the splines of the converter dragging on the input shaft. glad i got a warranty when i bought it in july, took it in and all was covered, just had the $100 dedutable and i didnt even have to pay all that. the shop tryed to convince the insurance Co to put in a whole new tranny for fear of metal shavings, but they opted for a new converter an said to come back when the tranny goes...stupid insur. co. tryen to save $$ now when they may have to pay for labor twice if the tranny goes. but shop said tranny looked very clean, so im not worried.
Copy of TSB:
99-3-5 - Noisy T/C*
Problem - Some 1999 F-series with the 4R100 transmission may exhibit a rattle/scraping noise in the converter housing area of the transmission case.
Action - To diagnose, place gear selector in park and using a break out box, ground pin 54 (TCC). This will fully apply the torque converter clutch. Cycle the torque converter clutch on and off a few times by applying and removing the ground to pin 54. If the rattle/scraping noise is not present when the converter clutch is applied (pin 54 grounded), replace torque converter.
Affected Vehicles - 1999 F-Series Super Duty, 7.3 DIT, 4R100 and 1998-1999 E-Series built after 1/5/98. Some 1999 F-series 250HD/350/450/550 Super Duty and 1998/1999 Econoline Series (built after 1/5/98) and equipped with 7.3l diesel
Parts - Updated Converter: XL3Z-7902-DARM
99-3-5 - Noisy T/C*
