Fuel Drain Back
Old Mar 11, 2007 | 08:01 PM
Jailhouse Jim's Avatar
Jailhouse Jim
Fuel Drain Back
I have a 2001 F-250 with 102,000 mi. Overnight it acts like it is draining fuel out of the system because upon start -up it misses (no smoke). It can idle for a few minutes adn clear up or you can press the accelerator to the floor and it will clean-up right away. It doesn't always do it. After first start-up, it starts great and runs great all day. Is there a check-valve anywhere in the system that holds fuel in the filter? It used to take a few days for it to act like this, now it happens overnite.
Jailhouse Jim
Old Mar 11, 2007 | 09:19 PM
Ultramagdan's Avatar
Ultramagdan
Hello Jim and Welcome to Ford Truck Enthusiasts!
You will want to post your question in the tech forums since this one is used for introductions. Click on the Forums tab at the upper left and look over the choices. Several should stand out to you. I assume your truck is a diesel and with that I suggest this forum: https://www.ford-trucks.com/forums/forum31/
Also stop by the California chapters, they are towards the end of the forums listing.
Enjoy the site!
Andrehill34
New Member Introductions
Oct 21, 2007 05:39 PM
Thubert68
Oct 4, 2007 04:43 PM
steamtrainrider
Sep 1, 2007 09:38 AM
dwags15
Mar 18, 2007 05:48 PM
reeseracing14
Jan 1, 2007 12:25 AM
