I need a general appliance tech!!!!!!!
Old Mar 11, 2007 | 06:59 PM
ag30265's Avatar
ag30265
Folks I have a kenmore dryer,it's an older unit maybe 8-10 years, Last week it started making a raquet, like a clicking noise. Sounds like a bearing popping or something. It still works normal on every setting and drys the clothes like it always has. I pulled the back of and checked things out. Can't really find anything wrong. Cleaned the unit out and put everything back together,it still works and still makes the noise. I didn't dissassemble the whole thing and check everything out just took a good look and cleaned it. Any body got any ideas or is familiar with this stuff?
Thanks, ANG.
Old Mar 11, 2007 | 07:05 PM
scole250's Avatar
scole250
Open up the access door and see if the belt or idler pulley needs replaced.
Old Mar 11, 2007 | 08:32 PM
SpyFoxx's Avatar
SpyFoxx
There are two rollers (that have sealed bearings I think) that support the drum on the opposite end from the motor/belt/pulley. They go bad over time. You have to remove the drum to get to them. They are only a few $$$ and I suggest you replace both of them. It is an easy job. You were not very far away from finding them.
Old Mar 11, 2007 | 09:08 PM
ag30265's Avatar
ag30265
Well I saw the roller on the bottom right side opposite the motor. I pryed on it and it moved a little but when I ran it and got close to where that roller is the sound seems like its coming from the front topside top of the machine. I don't know. Thinking bout lettin it die and goin to get a new one.
Old Mar 11, 2007 | 10:09 PM
petes79f150's Avatar
petes79f150
Yep- turn it into a Georgia flower pot. Set it out front, fill it fulla dirt, and plant some maters.
Old Mar 12, 2007 | 04:03 PM
rebocardo's Avatar
rebocardo
Most of the OEM dryers have a kit that comes with belts and rollers for about $29.00
Depending on the dryer, sometimes the click comes from a wobbling tub hitting the rubber around the vent opening behind the tub.
fwiw
krewat
Aug 28, 2006 09:09 PM
94van
Aug 15, 2005 07:29 PM
bigrigfixer
19
May 25, 2005 11:46 PM
Supercab
May 4, 2003 08:55 PM
