Hard Starting???
Old Mar 11, 2007 | 06:40 PM
jv42287's Avatar
jv42287
Unhappy Hard Starting???
I have a 1997 3.0 Ranger, 4x4, 120,000mi, 5spd. It has had a hard problem starting since I bought it when it is hot. I figured that it was the starter going bad and might be missing so i put a new one on. However, it has started again with the onset of warmer weather. It starts fine when its cold out but when it is warm, the problem starts. It starts up just fine when I first start it for the day. However, when I shut it off and leave it for a few minutes, like getting gas, it does not want to start again. It takes from 2 to 4 times to turn over when warm. Any ideas why??? Thanks John
Old Mar 11, 2007 | 07:05 PM
Benaghetto's Avatar
Benaghetto
Sounds like vapor lock if it wont start after already being warm and not starting. I forget what to do to fix it but that's what it sounds like to what I've heard. Just something about the pressures building up to be so great and your computer senses it and wont allow you to start it.
Old Mar 11, 2007 | 10:46 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
It's almost impossible to vapor lock this vehicle, as the pump is in the tank.
Exactly what do you mean by "not wanting to start"? Is it cranking slowly? Or is it cranking normally and just not "catching"?
Old Mar 12, 2007 | 07:02 AM
sfcwoodret's Avatar
sfcwoodret
Check the connections to the starter, and battery.
Old Mar 12, 2007 | 04:34 PM
jv42287's Avatar
jv42287
It cranks normally, it just doesnt want to grab. And the connections to the starter and batter are good, they are all new. Nothing sounds bad either, it just doesnt want to start?!?!
Old Mar 12, 2007 | 09:00 PM
aquanaut20's Avatar
aquanaut20
Check for a leaky injector flooding the engine, check the fuel pressure at the rail.
Old Mar 13, 2007 | 10:00 PM
jv42287's Avatar
jv42287
I double checked the connections to the starter and battery today. Everything is good. I am going to try to check the fuel system but I am not to familiar with it. Ill do what I can. Thanks for the Help!!
ddowell1
Aug 16, 2013 01:54 PM
rv7plt
Mar 13, 2013 07:53 AM
ahgoo
Oct 10, 2011 09:29 AM
John Blue F250
Modular V8 (4.6L, 5.4L)
May 20, 2009 05:52 PM
John Pen
1978 - 1996 Big Bronco
Apr 18, 2006 02:31 PM
