i have a 1986 F150 I6/300 w/C6 tranny.
not sure type of ignition, has no points, no ignition module.
1 wire to coil is hot but no spark from coil to dist cap.
found distributor mounted module, but cant see how to remove it.
see 2 mounting holes but cant see into holes, phillips dont work, flat dont work and hole to small 1/4" nut driver
Both NAPA and Autozone should carry a "TFI Module Wrench."
