Ranger 351w Swap
Old Mar 11, 2007 | 01:41 AM
89Mustang's Avatar
89Mustang
Ranger 351w Swap
I trying to research this swap and I need some help finding more info. I would like to know what the easiest year ranger would be the easiest/cheapest? From what I understand the explorer is very similar and they came with a v8, so does that mean that most of the parts could be taken off of an explorer? Like the kmember? Would that be the easiest way to go, to use an explorer for parts? My goal is to have a 351w based Ranger with a manual trans, I want to use it for track and street use. I prefer EFI and roller cam(94-up block) but Im not against the opposite, so if anyone has any usefull info or opinions please post.
Thanks
-Pete
Old Mar 11, 2007 | 03:23 AM
baddad457's Avatar
baddad457
If you have a 98-up Ranger, using an Explorer or Mountaineer for the swap is the way to go. Everything bolts right in. Otherwise you'll need to do the swap same as others, drill/cut the cross member to mount Mustang motor mounts, use one of three or four headers that work with the 302 swap (351 will be harder here, due to the wider engine) Move or fab a transmission cross member for the transmission. Wire the EFI harness yourself. There are two V8 Ranger sites for more info I know of where all this has been covered many times. Do a search to locate them, the filters here don't allow me to post the site names or links directly. or PM me and I'll tell you.
Filthy_F100
Jan 17, 2017 04:38 PM
gtmustang00
Jul 3, 2016 08:36 AM
ss27gogeta
58
Jun 21, 2016 06:10 PM
blacklab1
Feb 2, 2014 08:37 AM
gccch
1983 - 2012 Ranger & B-Series
Oct 14, 2008 10:00 AM
