Sponsored by: Auxito
Wiring Problem - need help
Old Mar 10, 2007 | 07:17 PM
Basic understanding's Avatar
Basic understanding
Post Wiring Problem - need help
Right turn signal blinks rapidly when turned on. Right front signal working but flashing rapidly, rear right signal not working. Right rear brake light does not work. Park lights and 4 ways all work. Backup lights and license plate lights work. Left side works fine.
Checked the bulb and replaced with a new one, still have same problem. Thought the problem was corrosion due to trailer plug cover being broken off and letting in moisture. Replaced trailer receptacle and still have problem.
As I mentioned, 4 ways work all around the truck, even the bulb on the right rear that doesn't work but is the same for the turn signal and brake.
Old Mar 10, 2007 | 07:46 PM
alberta46's Avatar
alberta46
could be your multi function switch there is a lot of posts about this problem search multi function switch should point you in the right direction.
Old Mar 10, 2007 | 07:59 PM
screwy's Avatar
screwy
Well looking at the wiring diagrams the only place something like this could happen is in the multifunction switch.
Old Mar 10, 2007 | 08:12 PM
lariat97's Avatar
lariat97
My truck acted like this & it was my multifunction switch. Its not hard to change.
Old Mar 11, 2007 | 05:17 PM
Basic understanding
Thanks for the help. I was searching through the posts and found a similar situation but with just the brake lights. The problem was the multifunction switch. Appreciate all your help.
