Will this work
Old Mar 10, 2007 | 05:13 PM
mattsf-100's Avatar
mattsf-100
Will this work
Hey guys. will the front clip from a 1964 ton truck inter change with 1964 f-100 pickup?
I can get the hole clip for 100.00.
Thnaks
matt
Old Mar 10, 2007 | 05:26 PM
airharley's Avatar
airharley
Take a few measurements to be sure but I do believe the F100-350 had the same front sheet metal.
Old Mar 10, 2007 | 09:10 PM
jared66's Avatar
jared66
I think the bigger trucks might have larger openings in the wheel wells.
Old Mar 10, 2007 | 09:59 PM
banjopicker66's Avatar
banjopicker66
If I remember right, the core support is different, and won't fit. Meaure the distance between the front frame horns, that will tell you real quick.
Old Mar 11, 2007 | 07:57 AM
mattsf-100's Avatar
mattsf-100
the guy at the scrap yard swears that the grill and support will fit. and that the inter fender wells will too. He wont sell me just the parts I need I have to buy the hole thing. But what to do with the extra parts??? I don't need the fenders. going to make do with what i have but I was sure hopin that the grille and support would work that would save me tons of money.
thanks
Matt
Old Mar 11, 2007 | 08:51 AM
1996pwrstrk's Avatar
1996pwrstrk
If the fenders are in good shape take some pictures and send them to me I might buy them if they are better than what I have.
Old Mar 11, 2007 | 08:30 PM
Highboy4x4's Avatar
Highboy4x4
The entire F350 clip will fit your F100. I used one from a F600 to put on my F100 and only had to change my fenders and stone guard. The only differences are the right inner fender will look different in the rear next to the cab since the battery is mounted in the floor on the F350 and the front stone guard is different on the larger trucks as it is straight down rather than flat like your pickup. Some F350 fenders are different as well to accomadate the larger tires. Hope this helps you out.
