95 explorer trans
Old Mar 10, 2007 | 03:31 PM
Shovelhead 93's Avatar
Shovelhead 93
Cool 95 explorer trans
Well it seems the trans in my 95 explorer has had enough, replaced the servos so Im told and no fix.It started the other day not wanting to shift from first to second unless you lift off the gas and then it would shift.It worked great up until then,it has 300,000k on it .I was told the bands would need replacing and the rebuild would be from 1,400to 1,700.He said the scanner showed all the selonoids were working fine,just that the bands were shot.Anyone have a good cheap trans for this has to be 95-96 or mazda b2000.Peterborough.If I cant find one cheap I will be scrapin the old girl.To bad I liked her!!
