Which Brake Master?
Old Mar 11, 2007 | 05:40 AM
GreatNorthWoods's Avatar
GreatNorthWoods
If you had a firewall mounted pedal you could increase the length of the pedal for more leverage. I'm not sure if that could be done with a pedal mounted under the floor. I always forget which way the bore sizes go from manual to power...up or down so if you have a 15/16 bore now perhaps a larger bore will help...not sure.
Old Mar 11, 2007 | 05:58 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1961/66 F250's 4X2 or 4X4 with manual drum brakes use a master cylinder that's 1 1/8"
C1TZ-2140-B
Bores increase with power brakes, at least that's what I found while looking for a 1 1/8" master without a power booster (the one I listed is about it). Most of the pre dual master cylinders without a booster are 1 inchers. With a booster the m/c sizes increase to between 1 1/8" & 1 1/4"
Old Mar 11, 2007 | 07:04 AM
1949f1's Avatar
1949f1
Originally Posted by Randy Jack
Because I'm concerned that the under floor power brake setup I can buy from most vendors will:
1. Put the master cylinder aft of the floor fill hole.
2. interfere with my (FMX) tranny crossmember.
I am looking for an softer pedal to activate the brakes I have without going to the power brake conversion.
I could go to a hanging pedal setup, but I'm looking for a less complicated option.
Please stop talking about power brakes and answer my question. I'd appreciate that.
randy,the under floor set up i got from no limit has a remote fill and my cross member for my fmx went between the set up and peddle.i had the same concern as you when i found this set up.
Old Mar 11, 2007 | 09:45 AM
Randy Jack's Avatar
Randy Jack
Thanks all for the responses.
Vern, Bill - That was my understanding also - that MC with power are bigger diameter to move more volume. I figured I should be looking for a smaller bore to have a softer pedal, but was concerned that I may not move enough volume to work the disks. I'm a little surprised that my 15/16" diameter is so stiff, when 1-1/8 is a common size for manual brakes. Maybe the problem is the under floor setup limiting leverage.
I'll check out the 65-66 Mustang manual disk MCs.
49 - I haven't seen the No Limit setup, but I like the remote fill idea. I'll check that out also. Power brakes would certainly be a better plan. And if I can squeeze it in there around that crossmember, that would answer my concerns. Thanks.
Colonel - I hadn't thought of blocking you. But thanks for the idea. I'm sure glad you're not trying to offend anyone.
Old Mar 11, 2007 | 03:45 PM
Col Flashman's Avatar
Col Flashman
Same Olde Grump, be a Git if you so choose & your Welcome for the Link to the Article about the Brake M/C you Queried.
And just because You believed that was my intent, doesn't make it so.
You're also not the one that has pulled victims out of Wrecked vehicles, some being "Chopped & Channeled" & after the accident investigation it's been found the stuctural failure was due to the new Welds giving way causing the Majority of the Injuries, such as decapitation.
Old Mar 11, 2007 | 05:23 PM
B/B ford's Avatar
B/B ford
Clean & Classy
You're also not the one that has pulled victims out of Wrecked vehicles, some being "Chopped & Channeled" & after the accident investigation it's been found the stuctural failure was due to the new Welds giving way causing the Majority of the Injuries, such as decapitation. [/QUOTE]
Old Mar 11, 2007 | 05:27 PM
Col Flashman
Old discussion that he took as a personal insult to his welding capabilities.
Even Master Welders under Controlled conditions make mistakes or something they are unable to fore see can transpire, so Any backyard welding is even more suspect.
angrymade
May 9, 2013 05:24 AM
alienbaby17
Jul 5, 2006 07:43 AM
TomC
Jan 1, 2000 05:24 PM
Charles
Aug 20, 1999 08:09 AM
