03 E350 speedometer & voltage gauge not working
Old 03-10-2007, 12:19 PM
BrotherTommy's Avatar
BrotherTommy
BrotherTommy is offline
Question 03 E350 speedometer & voltage gauge not working
I changed the 6.8 engine (it locked up) and ever since the speedometer and votage gauge in the instument cluster have not worked.
I have 2 of the factory manuals, but not the electrical wiring manual( I thought it would be in there.
Any help would be appreciated
Old 03-10-2007, 06:14 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,702 Likes on 1,376 Posts
Did you happen to change the engine computer during this repair?
Was this a direct replacement job with a identical junkyard or re-manufactured engine?
Old 03-10-2007, 07:03 PM
BrotherTommy
No computer change. The engine is a ford reman.
Old 03-10-2007, 07:45 PM
Franklin2's Avatar
Franklin2
Check all the fuses under the hood and under the dash.
Is the abs light on and does the cruise control work? If not, and the speedo doesn't work either, it may be something wrong with the speed sensor, possibly a fuse that powers some part of it's circuit.
reptyls
01-25-2015 06:35 PM
Ironmike86
02-20-2014 02:02 PM
Aune163rd
1983 - 2012 Ranger & B-Series
06-03-2012 09:16 PM
DeanBob
05-09-2012 11:51 PM
A87
Aerostar
11-16-2005 09:12 PM
Quick Reply: 03 E350 speedometer & voltage gauge not working
