Sponsored by: Real Truck
99 v10 electric problems
Old Mar 10, 2007 | 10:27 AM
smith99's Avatar
smith99
if u turn the key off and take with u, the fan still runs and the blinkers will still work the driven lights will come on after a few minutes.thanks for ur help
Old Mar 10, 2007 | 11:56 AM
Monsta's Avatar
Monsta
Sit. Stay.
Try turning on the headlights and then disconnecting the battery for about a 1/2 hour.
I've had weird things like that happen and a reset fixed it.
If that doesn't help, I would suspect that you need a new GEM. (Generic Electronic Module)
Old Mar 12, 2007 | 07:54 PM
smith99's Avatar
smith99
thanks ill give that a shot
Old Mar 12, 2007 | 09:21 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
This is also a sign of a water leak on the passenger-side windshield dripping down onto the through-the-firewall connection, shorting stuff out. At least, that's what's been talked about before...
Check the passenger side rug for water...
