I've got a '90 Eddie Bauer Bronco. When I put in a new fuel pump, I broke the plastic fitting that attaches the fuel line to the fuel pump.
I got a new fitting from Ford and glued the fuel line to it, but after a few months it blew out leaving me stranded (I don't see how you can fix this - any ideas let me know). I really shouldn't have tried this in the first place.
Isn't there some kind of steel braided high pressure hose I can replace the plastic line with - or should I just have one made (I think the dealer wants big bucks for a new plastic line - you have to buy both the send and return lines as a package).
You may get by with fabricating a high-pressure braided steel line, but the dealer can make up a line for you with the factory fittings (most keep them in stock in their parts depts.) I don't know if your Bronco's sending and return lines are somehow made together, but mine are separate, and I just had the one made when I cracked my fitting (on an '85 302 EFI). It was pricey (at around $45, I believe), but there was no hassle involved. I simply took in the old line to use as a pattern, and picked up the newly made one 20 minutes later.
Budman, what did you do about the Bronco fuel line? I've got both the feed and return broken on my 90 Bronco at the tank/fuel pump end. Did you buy a new line, get Ford to fix the old, or fix it another way, and how much was it? Obviously I want to fix mine as cheap as possible. I had hoped there would be an aftermarket one available by now.
