Cleaning Throttle Body
Old Mar 9, 2007 | 07:23 PM
rpatrick's Avatar
rpatrick
Guys,
I took my throttle body off on the '93 today to replace the TPS and the back side of the TB and the intake manifold has a lot of black oily residue on it.
The TB has a sticker on it saying not to clean it and I've had one other member tell me not to clean it.
So what should I do about the crud in the TB and manifold?
Why should the TB not be cleaned?
Thanks,
Rob
Old Mar 9, 2007 | 07:39 PM
Skandocious's Avatar
Skandocious
I sucked Seafoam through my break booster line to clean the carbon deposits out of the throttle body. Check out my vid:
http://video.google.com/videoplay?do...q=ford+seafoam
It's real easy and gave me a bit more throttle response.
-Chris
Old Mar 9, 2007 | 08:06 PM
rpatrick's Avatar
rpatrick
Chris - I seafoamed mine a couple of weeks back and it made a WORLD of difference.
But - the brake booster vacuum hose is well downstream of the throttle body on my engine - not sure if they are all that way.
It seems so simple to spray TB cleaner on it but I don't want to screw it up.
Rob
Old Mar 9, 2007 | 08:15 PM
matt0963's Avatar
matt0963
I've cleaned mine with some carb and choke cleaner (it was all I had). It worked.... Ive heard about doing the seafoam thing before though and these guys seem to think highly of it.
Old Mar 9, 2007 | 09:59 PM
Jason Lewis's Avatar
Jason Lewis
If you guys are talking about "Seafoam" that comes in a white/red Can it works great.
I fill up the front tank all the way then dump a can of seafoam in the tank
idol Response improves big time.
Then do the same with the rear tank.
http://www.seafoamsales.com/motorTuneUpTechGas.htm
Old Mar 10, 2007 | 09:14 AM
natewill's Avatar
natewill
The reason you're supposed to be selective about the chemicals that come in contact with your throttle body is because there is a thin 'liner' inside your TB where the butterfly valve shuts. If you use a chemical that eats that liner, your butterfly valve will not seal properly, and you'll soon be buying a new TB.
FWIW, I just cleaned my upper intake last weekend. I let my TB sit in mineral spirits for a day and a half, and now I have a very pleasing 700rpm idle that I didn't have before. So, be careful what chemical you use, but there is some room for experimentation.
Also, I used to twice a year take a toothbrush and a can of deep creep or TB cleaner, or whatever, and scrub away while the TB was on the engine. That might help a bit, too.
