1978 - 1996 Big Bronco
Brake pad clicking.....
Old Apr 1, 2002 | 02:34 PM
JBronco's Avatar
JBronco
Old Jul 9, 2002 | 08:28 AM
kilted_drummer's Avatar
kilted_drummer
Post Brake pad clicking.....
1990 Bronco 302......I just did an entire brake job, replacing everything. The thing is now that my right front outer brake pad clicks very loudly while driving. It is wheel noise as it speeds and slows with the wheel rotation. If I depress the brake pedal even the slightest amount, not even enough to turn on the brake lights, it goes away. I tried bending the tabs down on the pad itself to hold it in place a little better on the caliper, to no avail. It is one of the most annoying sounds I have heard. Someone help, please
Thanks, John.
Old Jul 9, 2002 | 09:47 AM
TheGreep's Avatar
TheGreep
You might try using some of the brake quiet on the back side of the pads between them and the caliper. I actually have the same thing happening with the new brakes on my bronco. I just don't care that much, it's not that loud on mine.
Old Jul 9, 2002 | 01:49 PM
firedude's Avatar
firedude
Ther should be little clips that hold the brake-pads in place to keep them from rattling.
Old Jul 30, 2002 | 04:06 PM
kilted_drummer
That style caliper does not use clips to hold it in place...could it be a bleeding problem?
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
