vacuum pump location?
Old Apr 18, 2005 | 09:10 AM
portlandtn's Avatar
portlandtn
OK. I must be an idiot. I have a 99 F250 4x4, 7.3L diesel. I don't where the vacuum pump is and I am to cheap to buy a shop manual. I have looked and the belt does not power anything that looks like a vacuum pump. On the passenger side, directly behind the battery is what appears to be a vacuum tank. Behind that an electrical unit with a small vacuum line to the tank, this item is mounted to the firewall and has a round piece sticking out a few inches. If this truck has an electric vacuum pump, I think that may be it, I hope so. It would be an easy change.
If you guys can get me through this you will have proven your superiority of truck repair.
I never give up. Thanks, Joey
Old Apr 18, 2005 | 09:30 AM
F0rdF0rever's Avatar
F0rdF0rever
Joey, if your engine layout is the same as my 95 which I think is, its right above the power steering pump on the drivers side.
Steve
Old Apr 18, 2005 | 09:33 AM
portlandtn's Avatar
portlandtn
I will go look right now.
Old Apr 18, 2005 | 09:37 AM
portlandtn's Avatar
portlandtn
oh no. all that is above the power steering pump is the altenator.
Old Apr 18, 2005 | 09:45 AM
Finally's Avatar
Finally
portlandtn
I've got a '99 PSD and the electric vacuum pump is on the passenger side, right where you thought it was. It controls vacuum to the ESOF and also runs the door on the HVAC fan.
Old Apr 18, 2005 | 09:55 AM
portlandtn's Avatar
portlandtn
The wife got tired of my nonsense. She called the dealer. This has an electric pump, located on the passenger side behind the vacuum tank. The fuse box is on the drivers kick panel. I will probably get this fixed at some point. I will not quit trying. I love this truck.
Old Apr 18, 2005 | 09:56 AM
portlandtn's Avatar
portlandtn
Another fix. Thanks finally.
Old Apr 23, 2005 | 12:35 PM
RedTaurus94's Avatar
RedTaurus94
So....did you buy a new pump? Where did you get it and how much did it set you back??
Old Jun 26, 2005 | 11:46 AM
portlandtn's Avatar
portlandtn
I took it to the dealer and got ripped a new hole in the wallet. It turned out to not be the electric pump, located on passenger side firewall. It was some kind of valve assembly.
xjcamaro89
2004 - 2008 F150
463
Feb 13, 2026 05:07 AM
MT4x4guy
Sep 16, 2013 01:04 PM
mmenzies
Nov 7, 2012 12:02 AM
portlandtn
Apr 16, 2005 08:35 PM
