Need Autolite 4100 advice.
Old Mar 9, 2007 | 12:19 AM
ClatonK's Avatar
ClatonK
Exclamation Need Autolite 4100 advice.
I bought a Autolite 4100 carb on E-bay. It has the 1.08 venturi size and 6AAB stamped on it. The intake I will be using is the stock Ford dual plane intake. The engine it will be used on is a 302 with dual exhaust and a RV cam in a 1972 Ford E200 Van, Automatic transmission. You can see the carb at E-bay it is E-bay number 320087727529.
Questions are?
Is this carb from a 289, 390?
What would be the best guess at jet sizes for this set-up?
This carb doen't have the automatic transmission kickdown bracket. Can I put one on? Can I use the one from my current Autolite 2100?
Clayton
Old Mar 9, 2007 | 01:08 AM
LxMan1's Avatar
LxMan1
I would guess 289, since it has small looking venturis. I don't know if you can swap the front throttle shaft or not. They look very similiar.
AbandonedBronco
Jan 22, 2015 12:01 PM
shakedownshorty
Dec 2, 2014 08:26 AM
jack orchard
Mar 16, 2013 04:50 PM
kadrocker
Feb 4, 2010 10:42 PM
F-250 restorer
Apr 13, 2009 02:59 PM
