Bronco II Ford Bronco II
inner fender removal
Old Mar 8, 2007 | 12:20 PM
todd koebel's Avatar
todd koebel
Ok, here's the deal. After getting my 89 bronco II running after two years, my brother immediately runs it intoo a tree. Now the passenger inner and outer fender are smashed. I've got the outer fender off, but can't figure out how to remove the inner fender. I have tried grinding, chiseling, and pounding it, but the welds won't budge. I've got an 89 ranger that I would like to take the front end off of and put it on the Bronco II.
Old Mar 8, 2007 | 03:31 PM
kernel-panic's Avatar
kernel-panic
Which "inner fender"? The one your outer bolts to, or the one IN the wheel well? One is removable, the other isn't quite removable, you'd have to straighten it and the radiator core support, or remove the core support and straighten the part that the outer fender bolts to, if I remember right. Not sure if the Ranger front end parts are the same and are interchangeable, either.
Old Mar 8, 2007 | 04:57 PM
todd koebel
The one the outer bolts to, it was pretty smashed up, so straightening out was pretty much out of the question
Old Mar 9, 2007 | 08:12 AM
kernel-panic
I don't recall those being removable... at least not without an air hammer or plasma cutter....
Old Mar 9, 2007 | 08:15 PM
todd koebel
I guess I'll have to try one of those, thanks.
Old Mar 9, 2007 | 10:47 PM
HappyJack's Avatar
HappyJack
If it's what I think it is, you need to drill out the spot welds. Might try doing a search for a kit for that.
Old Mar 10, 2007 | 06:50 AM
kernel-panic
Didn't think about that.... thanks for adding to, HappyJack.
Old Apr 18, 2007 | 08:03 AM
todd koebel
Wel, I tried one of those spot weld removers and broke both sides within fifteen minutes. Now, I am considering swapping out the body. Its pretty messed up anyway and I will at least be starting with a clean slate.
Old Apr 18, 2007 | 02:15 PM
kernel-panic
You may want to check around and see if anyone sells the parts you need, or remove the entire front clip including inner fender(s) from a junkyard, etc.
