Ac
Old Mar 7, 2007 | 05:52 PM
Russ8393's Avatar
Russ8393
Ac
I have an 98 Ford Ranger and my ac/heater has started blowing out of the defrost instead of the dash or the floor. What can cause this?
Old Mar 7, 2007 | 06:01 PM
fflintstone's Avatar
fflintstone
Welcome to FTE
Do a search on the Blend door or blend valve. There's been a lot of discussion on this problem with lots of solutions to it. I've never run across it myself, but a search should help.
Good luck
Fred
Old Mar 8, 2007 | 04:14 AM
skipper12's Avatar
skipper12
Yep i had this exact same problem with my ranger awhile back,,found out it was a broken vaccuum line,,i kept putting it off because i had no idea where to find it and one day my alternator went out and while replacing it stumbled on a little broken red plastic line,when i reconnected it with a small piece of rubber line,it was like majic all my vents worked again for the first time in years,you wouldn't believe all the dust that blew out of them from sitting idle all that time.
