302 rebuild question
Old Mar 6, 2007 | 02:58 PM
squeals's Avatar
squeals
over the summer i am wanting to rebuild my motor and i want to kinda beef it up a little bit... not so much for pulling, but more for power in general... i have a 1995 f150 2wd with a 5.0L and i was wondering of some ideas of what to do with a budget of around a grand to 1500... and my lifters are already startin to click so those will have to be replaced...
i have a garage that i can work in and a shop nearby that replanes heads and bores and all that stuff too so that could be in the options...
thanks
Jesse
Old Mar 7, 2007 | 09:28 AM
Kemicalburns's Avatar
Kemicalburns
for that money, i would get a cam and lifter set, have the e7 heads worked over and get some good quality headers, and redo the exhaust from there back.
whats the mileage on the motor?
Old Mar 7, 2007 | 04:15 PM
squeals's Avatar
squeals
just about 115k
but im goin to college this summer and am gonna need a reliable vehicle to drive around indianapolis and i live about 2 hours from there...
Old Mar 8, 2007 | 11:30 AM
WarWagon's Avatar
WarWagon
I would build a stroker
Old Mar 9, 2007 | 04:48 PM
squeals's Avatar
squeals
how much would it cost to build a stroker though? ive only got a certain amount to work with and that involves a new crank and all that good stuff
basically a new everything
Old Mar 10, 2007 | 09:17 AM
WarWagon's Avatar
WarWagon
I guess if you are on a budget with a 302, forget the stroker. A 351 is another story. The only thing additional on one of those is the crank and pistons, but you will be buying pistons any way. A 351 stroker (393) only adds about 2-300 to the build.
Old Mar 11, 2007 | 10:45 AM
matt0963's Avatar
matt0963
I suggest a reman engine, with aftermarket cam, hearders, and exhaust, that will wake up the truck with out hurting the budget too much. Thats what I did on mine, see my gallery for pics
Old Mar 11, 2007 | 05:02 PM
squeals's Avatar
squeals
im guessin you still put new pistons in too though right?
Old Mar 11, 2007 | 06:14 PM
squeals's Avatar
squeals
wait... just read your post again and caught it... so are you sayin get a cheap crate motor? or what? im not good at this terminology and i kinda want to rebuild this more for a learning experience more than anything
Old Mar 11, 2007 | 10:53 PM
matt0963's Avatar
matt0963
I went to Advance Auto Parts and ordered a remanufactured engine, It is remanufactured not rebuilt (theres a difference). It came with the block, heads, and timing chain set. I took my engine out swapped the intake, tinware, and accessories, ect over to the new engine, swapped in a new cam, and put it back in the truck. The motor was remanufactured by recon.
This will help explain the difference between rebuilt and remanufactured
http://www.reconengines.com/../enginecomp.html
Old Mar 12, 2007 | 12:15 AM
preppypyro's Avatar
preppypyro
What kind of prices did you pay for that engine matt? What kind of cam did you put in?
Old Mar 14, 2007 | 08:37 PM
matt0963's Avatar
matt0963
I paid about 850 for the engine, It came with the roller cam and lifters (HO fireing order) and came with the GT-40 heads. I called Crane Cams and they custom made a cam for this set up and speed density computer. Cam was about 300. The headers were 300. New dual exhaust was 150.
Old Mar 15, 2007 | 12:50 AM
preppypyro's Avatar
preppypyro
You got a pretty good deal there!
Jesses1999f250
Jan 4, 2015 10:55 PM
Jesse Grass
New Member Introductions
May 16, 2013 05:37 PM
StumpPullerF1
Jan 29, 2011 11:36 PM
Jesse Zimmerman
1978 - 1996 Big Bronco
May 25, 2010 01:02 AM
jesse
Aug 5, 1999 05:13 AM
