Code P0344 CPS and P1280 ICP now what?
Yes, reset the PCM, pull #9 fuse. But get the codes pulled ASAP. The PCM may have stored your most recent CEL.
ICP wires may cause your intermitant CEL. Repair it if it looks bad to you.
The following is ICP function(s):
Return the truck to stock then see if it does it.
The ICP sensor's primary function is to provide a feedback signal to indicate rail pressure so that the PCM can command the correct injector timing and pulse width and the correct injection control pressure for proper fuel delivery at all speed and load conditions.
If the PCM detects a malfunctioning ICP sensor the CHECK ENGINE light is illuminated and the PCM will go to open loop control of injection control pressure. (Operate from an estimated injection control pressure.)
What was your FP after the FPR shim? Mines @ ~80 psi. It's difficult to read cuz the FP gage bounces so much but you'll get the idea. Sometime shimming the FPR will cause a weak (old) fuel pump to act up.If the PCM detects a malfunctioning ICP sensor the CHECK ENGINE light is illuminated and the PCM will go to open loop control of injection control pressure. (Operate from an estimated injection control pressure.)
I am pretty sure i have the right CPS. The guy at the international dealer said that either of them would work fine, but i took the one for pre 1997 just in case. My truck is a 1995. I'm thinking that it wasnt the CPS at all now that i have the same exact symptoms with a new one. Right now the batteries on the truck are unhooked to try and reset the computer just in case it is still running differently because of a stored code. Can anyone show me a diagram of the under hood fuse panel? I dont have the owners manual and there is no diagram on the cover.
Cuda, I am not sure what my new fuel pressure is. I will re connect the batteries and see how the truck acts around lunch today. If it still gives me a problem i will pull the chip and see what it does. If that doenst help i'll remove the BB from the FPR and see what happens. I'll start putting things back starting with the chip and see where the issue is. I'll probably end up fixing up my ICP sensor connector also. Thanks
mrjimbov
40
03-31-2021 11:35 AM
jtharvey
19
04-15-2012 03:44 PM
fridgeddiesel
10-14-2009 06:42 PM
