Aerostar Ford Aerostar
How to improve cooling airflow?
Old Mar 6, 2007 | 08:05 AM
Zen Punk's Avatar
Zen Punk
I heard someone here say that the Aero's have poor airflow. I was thinking about putting in a tranny cooler and want to know if anyone has any suggestions for modding the grill/front end to improve airflow. Thanks!
Old Mar 6, 2007 | 08:32 AM
VanGo's Avatar
VanGo
Hmmm. I have too much airflow. There's cardboard in front of my radiator to try and warm it up faster. IMHO, you should be fine sticking it anywhere in front of the rad. Maybe you need a flush and/or coolant change if youare running warm?
Old Mar 6, 2007 | 09:16 AM
MO51's Avatar
MO51
I have a 4.0 '96 that came OEM with the AC condenser, and the little tranny cooler and power steering cooler in front of the coolant radiator. I have since installed an extra 8"x12" tranny cooler on the same surface as all the above . I've never noticed any problem with airflow/engine cooling, before or since, including pulling my camper over the Sierras in August at + 100 degrees. I think you'll be fine.
Old Mar 6, 2007 | 11:54 PM
xlt4wd90's Avatar
xlt4wd90
The common thing to do is to replace that stock loop of a transmission cooler inside the bumper with a plate type cooler. B&M makes a couple that should fit. Then reroute the power steering lines to use the stock transmission cooler and remove the stock power steering fluid cooler. This makes room in front of the radiator for the new plate cooler(s).
Toyman
2009 - 2014 F150
Oct 29, 2016 04:45 PM
JimG1098
May 12, 2015 10:58 PM
4X4 IN REFUGIO
6.4L Power Stroke Diesel
May 11, 2012 05:09 AM
RedneckTrucker
6.7L Power Stroke Diesel
16
Jun 14, 2011 05:28 PM
Spartan Racing
Dec 25, 2004 01:46 PM
