Towing in Overdrive
Old Mar 6, 2007 | 07:18 AM
hi-jacker's Avatar
hi-jacker
Towing in Overdrive
Providing the tranny isn't slipping in and out constantly, does anyone see a problem with towing heavy loads with overdrive on? For example, if I'm pulling a 15,000# 5th wheel across illinois, which is pretty much flat, it would be nice to run in O/D to get the best fuel economy. What I'm concerned about is whether the extra load while in O/D would cause the tranny to run too hot. Thanks.
Old Mar 6, 2007 | 07:31 AM
p8ntballn2's Avatar
p8ntballn2
get yourself a nice set of gauges... that way you can m onitor everything.. i love mine.. and it only took me 2 hours to install.. www.dieselmanor.com has the best kit IMO and the best step by step directions.. my $.02
Old Mar 6, 2007 | 09:07 AM
johnnysF350's Avatar
johnnysF350
Tow in Drive (D) with the tow haul mode on. This is how the torqueshift is designed to tow under all conditions. I have towed up mountains with mine and never used any position other than (D) with tow haul on and never had a problem. This transmission is very smart and does not hunt gears at all. It knows and picks the appropriate gear it needs to be in very efficiently
Old Mar 6, 2007 | 09:24 AM
tclingan's Avatar
tclingan
my experence with gauges and transmissions is that once the reading is not normal its to late the tranny is already cooked...
Old Mar 6, 2007 | 10:26 AM
Kep4's Avatar
Kep4
Jäger
Exactly right! The TorqShift is much improved over the 4R100 and especially the E4OD transmissions. Just leave it in Drive and engage Tow/Haul when you're towing heavy loads. The TorqShift '3', '2', and '1' positions actually place the transmission in that exact gear with no upshifts or downshifts so it's best to leave in in 'D'.
FYI, I tried Tow/Haul pulling my old 3,000 pound pop-up trailer and it was too aggressive when down-shifting.
Good question hi-jacker.
Old Mar 6, 2007 | 11:45 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
In your 05 TS, you don't have any choice BUT to tow in overdrive. YOu can engage the Tow/Haul feature, but either way, you are always using overdrive.
Old Mar 6, 2007 | 11:51 AM
EZ-Ford's Avatar
EZ-Ford
This transmission is great. Just set it and forget it (well almost, watch your temp when pulling). In past units, it was advised to not use OD when towing. That is not the case with this one.
Old Mar 6, 2007 | 12:17 PM
marcs724's Avatar
marcs724
So is there a limit as to when you need to put tow/haul on or if its ok to just leave it off? I towed my enclosed trailer with all my tools the other day (about 7k) with tow/haul on and I don't think I really needed it on... truck really didn't work at all.
Old Mar 6, 2007 | 03:32 PM
fpd7's Avatar
fpd7
Even if you don't think to use it for accelerating, it sure saves wear on the brakes by using engine braking. I don't know of anyone, or literature anywhere that says what magic pound number to use Tow/Haul mode. In my opinion though, 7K should be heavy enough to have it engaged. It doesn't cost anything, and saves the brakes. Joe.
Old Mar 6, 2007 | 03:34 PM
dc3655's Avatar
dc3655
marcs724, If you're towing around 7k pounds, I would have the Tow/Haul on! It makes no difference except that it changes the shifting points which helps to save the tranny. The nice part is that you'll still drop into OD when the truck is rolling along at a stable speed if it deems it possible. But then again, that's all just personal preference. I haven't seen anywhere where it's been determined an actual weight of when the Tow/Haul button needs to be on.
Old Mar 7, 2007 | 05:28 AM
glsurratt's Avatar
glsurratt
Put it in Drive, punch in tow/haul but DON'T use Cruise Control. You'll find it hunting all over the place even on those flat Illinois roads where they rise a little bit for the overpasses.
Old Mar 7, 2007 | 09:42 AM
johnnysF350
Yeah, I have to agree with this, the cruise control in these trucks leaves a lot to be desired, even when not towing. The problem with it seems to be that it does not start tipping in the throttle quick enough. I notice it actually looses about 4mph or so before it attempts to apply throttle and by that time it's too late. It then overcompensates causing the truck to drop a gear to catch back up, which causes the hunting effect.
Old Mar 7, 2007 | 11:23 AM
firehawk198's Avatar
firehawk198
Great info to know. I've been pulling with a 99 350 V10 with a 5 speed stick 13,500# It is a lot of work, Looking forward to the new Auto
Old Mar 7, 2007 | 12:25 PM
dc3655's Avatar
dc3655
I got so sick of the truck hunting for gears while towing 30' enclosed trailers that I went and put a towing module in the truck. Now all that is gone! I absolutely love the new power and even out here in the mountains of the west, it takes a big mountain for it to even think about downshifting out of OD. Even in cruise control now it holds OD just fine and has enough power to get back up to speed without downshifting at 75 mph.....I love it!! This is why I'm such a firm believer in the torque of the diesels: They allow you to tow heavy loads in OD! My friend had me pull his Toy Hauler the other day to the dunes and back, he was so blown away that I was doing 75 mph at roughly 2000rpm that he's sold on the diesel and is looking for a used X PSD! I have to admit that it took a tuner to make me 100% satisfied, but sometimes that's what you have to do to really unleash the power potential in these trucks.
Old Mar 7, 2007 | 01:05 PM
hi-jacker's Avatar
hi-jacker
What truck do you have and which tuner? If you don't mind my asking.
