Sponsored by: Auxito
97 Ford 4x4 stuck in 4 wheel low
Old Mar 5, 2007 | 07:25 PM
bclifton's Avatar
bclifton
I have a 97 Ford F-150 4x4 that is stuck in 4 wheel drive low. Does anyone have any suggestion on how to get it out? Have tried driving it and going from reverse to neutral and to drive. The light on the dash is not on but it is still in low. Any suggestions would be great. Thanks
Old Mar 5, 2007 | 08:29 PM
Ultramagdan's Avatar
Ultramagdan
Hello and Welcome to the site!
Have you tried switching it with the gear selector in neutral and your foot on the brake? That should get it to shift, if it doesn't I would start by checking the wires to the switch motor alongside the transfer case.
Old Mar 7, 2007 | 04:26 PM
basecamp's Avatar
basecamp
Is this a manual shift or do you have a switch on the dash to switch from 4 low to 4hi? Many of these have problems with the electronic shift motor on the transfer case. If it is the electronic one then you have to be in nuetral and stopped or it won't shift out of 4 low.
Old Mar 31, 2007 | 04:43 PM
jdaniels's Avatar
jdaniels
I have the exact same problem on a 97 f150. I unhooked the connector to the shift motor and founf no voltage on any of the pins. Is there supposed to be? engine running i assumed there would be 12 volts somewhere. Its driving me to drink.. not a bad thing but a working truck would be better lol. No error codes in the puter either need the insight of a guru HELP!!!!!!!! fyi.. automatic tranny, 3 position switch on dash.. blue in color, chipped windshield lol
jrounsley
Mar 15, 2015 11:58 AM
Myst98
Mar 16, 2013 09:01 PM
keyul
1997 - 2003 F150
May 7, 2008 09:03 PM
GIO23
1997 - 2003 F150
Feb 28, 2008 02:52 PM
lakureyri
Jan 29, 2008 12:11 AM
