door ajar
Old Mar 5, 2007 | 03:29 PM
jawdoc's Avatar
jawdoc
door ajar
My first time in this particular forum. Im usually in the Superduty one. My 2003 Expedition always has the door ajar indicator on and now my battery has gone dead. Ive heard that you use WD-40 for this but where do I apply it? Where are the switiches for the door ajar sensor?
Thanks for the help,
Dave
Old Mar 5, 2007 | 05:15 PM
MisterCMK's Avatar
MisterCMK
Use the WD-40 on your door latches. The door ajar switch is located in the latch assembly and gets gummed up from time to time. A quick cleaning of the latches with WD-40 should take care of the problem for ya.
Old Mar 5, 2007 | 08:42 PM
jawdoc's Avatar
jawdoc
thanks for the help
Problemdrives me crazy! thanks MisterCMK
Old Mar 5, 2007 | 09:09 PM
MisterCMK's Avatar
MisterCMK
No prob, pretty easy fix for a really annoying problem.
Old Mar 5, 2007 | 09:21 PM
rockstate45's Avatar
rockstate45
When I do it I take a screw driver and prop the latch into the "closed" position and spray the WD-40 down there, then release the door handle and proceed to use the screw driver to move the latch and get it greased up nice.
-rockstate
Old Mar 5, 2007 | 09:56 PM
Zip's Avatar
Zip
I had this problem with mine when I bought it. I eventually had to take the door panel off and pull out the switch to clean it. All the WD40 I had couldn't make the light go out.
Old Mar 6, 2007 | 05:18 PM
sus1799's Avatar
sus1799
WD-40 fixed this problem for me. I sprayed it a couple of times in each latch. I opened and closed the door between sprays. Don't forget to do the rear window and lift gate. It's been 3 weeks now and it hasn't happened again.
Old Mar 14, 2007 | 08:41 AM
thereason21's Avatar
thereason21
I have been having the same problem on a 97 i just bought. Ill try it to see what happens.
Old Mar 14, 2007 | 06:33 PM
thereason21
Whaddya know it worked like a charm!!! Thanks MR. CMK
Old Mar 15, 2007 | 12:32 AM
kwegman003's Avatar
kwegman003
this just started happening to me a few
days ago...ill try the wd40 in the AM. how long does the dome light stay on when the door is ajar and the locks are engaged? hoppefully not too long but ive seen it after about 10-15 mins
Old Mar 15, 2007 | 12:36 PM
thereason21
I was just having this problem and before the WD40 they would stay on for up to a half an hour afterward they go off in less than five seconds for me.
Old Mar 16, 2007 | 12:15 AM
kwegman003's Avatar
kwegman003
strange story
Ive had this problem for around a week of leaving the EXP with the dome lights on hoping it would start on my return...and I looked on the forum for an answer and then that day it went away. I cant explain it but I believe that I have a truck that fixes itself...I cant wait for it to work on its suspension/ exhaust/ tuneup this summer while I sit on here and drink lemonaid...
chhers
Old Jun 13, 2007 | 04:55 PM
RisingPhoenix78's Avatar
RisingPhoenix78
Smile Dorr AJar
I was living with this insanity of the door ajar light...on off on off....I was so happy when I found this thread. What a simple fix for such an annoying problem. I was close to driving this truck off a cliff...thanks for the advice.
Old Jun 14, 2007 | 06:04 AM
MisterCMK's Avatar
MisterCMK
chhers
haha, is that how it works?
Old Nov 2, 2007 | 08:46 PM
mizjennyb's Avatar
mizjennyb
Hi all, I'm new to this forum. I currently have a 2000 Eddie Bauer Expedition that I'm trying to sale and wouldn't you know, the "door ajar" light has just come on - always something. I will try the WD-40 but I've also heard that PB Blaster does the same thing. This can usually be found at Wal-Mart - one of the mechanics at the Ford Dealership told me he likes PB Blaster better. Thanks for the tip.
