Need timing Help!!
Old Mar 5, 2007 | 01:11 AM
Chris91sho's Avatar
Chris91sho
Need timing Help!!
I just rebuilt the 302 in my 94 f150 4x4. Everything went pretty good until tonight...Trying to get the timing right and it's not going good. I set the motor at 10* Btc, line up the distributor timing marks, set the rotor to #1 and nothing. I keep reading about this spout connector but my distributor doesn't have one so where is it? Could this cause my problem? Someone please help me figure this cluster out! Thanx
Old Mar 5, 2007 | 09:08 AM
subford's Avatar
subford
You have to remove the SPOUT while timing, it is over by the hood hinge on the drivers side.
Here is an Image.
http://i54.photobucket.com/albums/g9...tion/SPOUT.jpg
Old Mar 5, 2007 | 10:05 AM
Chris91sho's Avatar
Chris91sho
Thanx Sub, I'm gonna try that today.
Old Mar 5, 2007 | 07:28 PM
EPNCSU2006's Avatar
EPNCSU2006
Make sure you're on TDC of the compression stroke...you might have the distributor 180° out, so that when cylinder 1 should be firing, the distributor is pointing at 6.
