Question about engine/tranny package
Old Mar 4, 2007 | 08:55 PM
elkslayerpaul's Avatar
elkslayerpaul
Question Question about engine/tranny package
Hi, I'm new to the club. I have a 57 f-100 that I picked up a year ago. The original motor was replaced with a 68 mustang 289 and c4 tranny.The engine runs great, but the tranny leaks badly. My problem is: the column shifter sends the linkage rearward and the tranny being a floor shifting mustang tranny needs to have the linkage sent forward. I contacted Lokar and they do not have a kit for this application. 1) Do I scrap both and try to find a better engine/tranny combo? 2) Will a c6 tranny from a truck or larger car fit the 289? 3) Can I do anything to the c4 to make the linkage go forward? any help would be super appreciated. Thanks, Paul
Old Mar 4, 2007 | 09:06 PM
51dueller's Avatar
51dueller
Can you flip the linkage lever on the tranny to the opposite side? Like top to bottom.
Old Mar 4, 2007 | 09:17 PM
elkslayerpaul
I have no idea. I'm not much a tranny guy. Thanks for the quick response. Paul
Old Mar 4, 2007 | 09:47 PM
Fomoko1's Avatar
Fomoko1
Welcome, nice to have you on board.
The valve body can be easily changed, it`s a simple inexpensive job for a transmission shop and not costly.
Someone may jump in and explain eactly what`s involved.
Old Mar 4, 2007 | 10:09 PM
ALBUQ F-1's Avatar
ALBUQ F-1
On the C4's I'm familiar with, the lever is keyed to the selector shaft ("D"-shaped rod and hole in lever). There are universal type levers that can be used.
Old Mar 4, 2007 | 10:55 PM
Col Flashman's Avatar
Col Flashman
I've a C-4 mated to a built 300 I-6 installed in my '58 Mercury M-100 & had No problem attaching the linkage to the Automatic Column Shifter & having it work properly, so I'm not exactly sure Why you are having such a problem w/ yours.
Old Mar 5, 2007 | 12:07 AM
Fomoko1's Avatar
Fomoko1
There are different valve shift bodies bodies, for floor shift and for column shift. The Mustang had a floor shift and the truck has the column shift.
I ran into this when I got a used C6 from a 67 XL 500 (floor shift) and installed it in a Parklane Mercury (column).
It confusing at first but a simple fix in the valve body.
Old Mar 5, 2007 | 08:48 PM
elkslayerpaul
Thanks a lot for all the info guys!! I think I will take it to a tranny shop and have the linkage flipped or what ever they reccommend. I didn't think it was possible to keep this engine/tranny package, but now I know I can! Thanks again Paul
