Sponsored by: Real Truck
Towing with an Automatic Transmission
Old Mar 4, 2007 | 04:57 PM
Pocono Super Duty's Avatar
Pocono Super Duty
In 3 weeks I will be heading south to Florida with my 04 SD 5.4L Auto Trans (4R100) 4:10 rear with a 3,000lbs truck camper in the bed. I have read in other posts, plus the owners manual that you should not tow in Overdrive. I have a few questions maybe someone can answer. When I tow with O/D off , truck RPM's seem to run around 2,700rpm at 60mph. Is this o.k. to do on a 1500 mile trip? I also read about torque converter slippage, but I don't understand what that is. I also read something about driving in O/D does not allow the pump to pump fluid through the cooler fast enough because of low RPM's. Any info on this would be great.
Old Mar 4, 2007 | 05:12 PM
bfloyd4445's Avatar
bfloyd4445
Transmission are toasted everyday by driving in od when towing. However, the torqshift was designed with a high output pump in the traNSMISSION TO MAKE IT RUN COOLER and ahs a larger radiator than earlier trannies. When I tow light loads I do it in od and have not had a problem in 110 on one truck, 130 on the other, but both my autos are filled with mobil one tranny fluid which is a full snythetic and dosent break down with heat. The killer of transmissions is the heat which causes the fluid to break down forming deposits on transmission parts killing it. Syn dosent break down so eliminats the problem. At least it has for me. Oh, and the funny thing is my gas mileage is the same when towing in or out of od. Strange, you would think that running at 3,000 instead of 2,000rpm would use more gas but it dosent in my trucks. My towing always involves climbing the Seirra nevada mountains, 8,000 feet up or the Siskiyou mountains, 7,000 feet so does make my trucks work. Flat land towing I do in od except when towing very large loads approaching max rating on my trucks, 8k or 10k depending if my F150 or F250.
Old Mar 4, 2007 | 05:14 PM
ReAX's Avatar
ReAX
I'll help with what I can. OD is another gear, for our trans it is 0.72:1. When you disable OD, your left with 3rd gear being the highest and I belive it is 1:1 or there about. I don't think 3K is enough to worry about in the super duty as far as the trans is concerned. It is a little heavier than rated for the truck to load to, 1.5 tons in either a .75 or 1 ton.
I would try it and keep a good eye on the trans temp. If it runs much hotter than normal, I'd click OD off. However as long as the trans temp stays level, I'd save a little fuel.
Old Mar 4, 2007 | 05:15 PM
FTL40's Avatar
FTL40
2700 should be just fine, it will just burn more gas, it may be worth while to install a good trans temp gauge so if it was to get a bit hot you could always pull over and let it cool down.
Frank
Old Mar 4, 2007 | 05:21 PM
wlihntr's Avatar
wlihntr
i have a 2500# truck camper and pull a 4000# boat and run in OD all the time. i havent had any problems. it doesnt say not to tow in OD in my manual, must be soemthing new.
Old Mar 4, 2007 | 05:34 PM
Pocono Super Duty
wlihntr,
I believe it's in the section "Driving your Vehicle". I'm going to go out to the truck and get the owners manual and read it again.
Old Mar 4, 2007 | 05:39 PM
bfloyd4445's Avatar
bfloyd4445
Smile
wlihntr,
Its there, Ford has had that in there to cover there *** since at least 1987 and maybe longer. As I mentioned earlier I tow light loads in od except pullin the hills< up to 10 k high out west here> A previous poster mentioned 3-4K loads in od and that i consider a light load for an SD. Shoot, that aint much more than a beer cooler and a couple of kegs is it guys?
Old Mar 4, 2007 | 05:52 PM
wlihntr's Avatar
wlihntr
wlihntr,
i just looked through the whole "driving your vehicle" and towing sections again ...i cant find anywhere where it says not to tow in OD
Old Mar 4, 2007 | 05:55 PM
bfloyd4445's Avatar
bfloyd4445
Humm, could swear it was there. Maybe with the new bullet proof torqshift tranny Ford dosen't see any need for it anymore. It used to be in there towing guide.
Old Mar 4, 2007 | 06:08 PM
brwolfjr's Avatar
brwolfjr
Hey Pocono - I will be making the trip from SE PA to FLA at about the same time. I'm taking the tribe on a mouse hunt! I just spent the weekend converting from "winter trim" to "summer trim". Removed the snow equipment and changed from my BFG MT's to my BFG AT's.
Old Mar 4, 2007 | 06:09 PM
savage2211's Avatar
savage2211
I pull a 13500 lb 5th wheel in od. I had a new trans put in last year at AAMCO.They got it from ford.They said is I used the hevyduty converter they would warranty it 3yrs 50000 miles.so i went for it. They told me to leave it in OD when i tow.I hope I have been doing the right thing...The trans temp stays down about 150 to 175 deg...
Old Mar 4, 2007 | 06:18 PM
Pocono Super Duty
I have read so many different things on this subject, I don't know what is the correct thing to do. I read as long as the trans is not shifting back & forth, O/D is o.k. I also read that fluid temp has something to do with it also. But the thing I read about most is torque converter lockup & slippage and I don't understand what that is except it creates a lot of heat in the transmission.
Old Mar 4, 2007 | 06:36 PM
bfloyd4445's Avatar
bfloyd4445
You made me remeber something about trannies. If the engine vacum is not in the right range the tranny doesnt lock up cause it thinks there may be a need to shift. It it runs in this, ready to shift mode, there is no lockup and lots of slipage which will indeed cause lots of heat build up. Since it is very hard to detect when your tranny is doing this you should have a synthetic fluid in place which won't break down under the heat and trash your tranny. I drive lots of miles in od and have never lost a Ford tranny as a result but I do run synthetic. With snthetic you don't have to change the fluid as often so in the long run you save money. You can tell when the fluid needs changing by its smell. Just smell the dipstick and the fluid should smell like out of the bottle if it dosent you better change it ASAP. Hey, with conventional fluid you may burn it after only a few miles if under heavy load with lots of climbing.
Old Mar 5, 2007 | 05:13 PM
2x6 bulldog's Avatar
2x6 bulldog
I always tow in O/D unless I get into a hilly area and the transmission starts shifting in and out of O/D. I'll take it out until the terrain flattens out again. I tow a 13,000 lb fifth wheel.
Old Mar 5, 2007 | 05:55 PM
bfloyd4445's Avatar
bfloyd4445
Yep, me to, or when pullin a really heavy load. What transmission do you have? Do you use syn or regular fluid?
