snow driving question
Old Mar 4, 2007 | 01:36 AM
mndiesel's Avatar
mndiesel
OK just bought the truck in August and have a question. We just received
2 1/2 feet of snow in 10 days. I noticed when I accelerated in 2 wheel drive in the stock setting in about 2-3 inches of snow the rear end starts bouncing instead of just spinning. I have never seen a truck do this. Is it because its so heavy or is there a potential problem arising. On dry pavement it just goes. Just want to make sure nothing is wearing out. Thanks in advance
Old Mar 4, 2007 | 02:11 AM
spunks00's Avatar
spunks00
i know alot of truck that do that on dry pavment...dont know why thought...
Old Mar 4, 2007 | 02:30 AM
Fordbronco69's Avatar
Fordbronco69
Infidel
Throw some weight in the back and you wont get the hopping.
Old Mar 4, 2007 | 03:27 AM
rollerstud98's Avatar
rollerstud98
it's a little thing called wheel hop, can happen on dry or wet pavement, thats why you see all those boys with traction bars on the camaro's and stuff like that, reason you notice it now is because your wheels are spinning, somebody else will be able to better explain it to you
Old Mar 4, 2007 | 03:31 AM
scottty's Avatar
scottty
WTH am i sleepy
Old Mar 4, 2007 | 06:46 AM
lancer's Avatar
lancer
Probably just the deep snow. My truck will do the same thing in deep snow. Like said before try some weight in the back of the truck. It should help. And if your trucks a 4X4 than use it!
Old Mar 4, 2007 | 08:17 AM
CruiserClass's Avatar
CruiserClass
Wheel hop happens when torque is suddenly applied to the drive axle. The pinion tries to climb up on the ring gear because the axles can't turn fast enough to keep the speed the same. This causes the entire rear axle tube and differential to tilt until the pressure from the springs snaps it back into place, which makes the vehicle hop.
You are getting hop because the wheels are spinning rapidly with no traction and then suddenly grabbing, making the torque reaction described above. Ladder bars work because they prevent the axle housing from twisting. Short of ladder bars, make sure your rear shocks are in good condition and be easy on acceleration.
Old Mar 4, 2007 | 08:35 AM
lancer's Avatar
lancer
Excellent explination Cruiser
Old Mar 4, 2007 | 08:44 AM
rdz's Avatar
rdz
my 90 f350 did it all the time in the snow. i think its the limited slip rear end. once she dug through the snow and started to get traction she started to hop didn't matter how much weight i had in it.
Old Mar 4, 2007 | 10:03 AM
mndiesel's Avatar
mndiesel
Cruiser, Thanks for the explanation and the help understanding how these beasts work. I never thought about having a vehicle with that much torque and how it would affect the truck in adverse weather.
Thanks to all those who responded
Old Mar 4, 2007 | 10:15 AM
pbr man's Avatar
pbr man
Unless you are in four wheel drive the front tires are not going to push through deep snow very easily and the rear end will hop trying to move forward. On these trucks almost 3/4 of the weight is on the front axle so you have the weight of the front holding you back while the rear end can't get traction. Weight the bed will help, but use 4x4 if you have it to not put the stress on the driveline and ring and pinion.
carltonwebb
Nov 15, 2011 01:20 AM
White F250
Feb 6, 2011 11:29 AM
VoodooRacer
28
May 15, 2009 05:33 PM
Jaspell
Dec 22, 2008 02:31 AM
444dieselrod
Feb 16, 2005 06:34 AM
