no start
Old Mar 4, 2007 | 12:30 AM
skunktruck's Avatar
skunktruck
Unhappy no start
hi everyone,
I have a 78 f250 that wont start anymore. I just rebuilt the carb and it started but the floot was out of wack. so i shut it off, and fixed it then i tried to start it but all i heard was a wierd sound from the what i belive is the battery area. so i cheacked the battery and i have full 12.53 volts. oh and none of the lights or the gauges work. just as if i have no battery hooked up.
thanks for any help
jim
Old Mar 4, 2007 | 12:50 AM
LxMan1's Avatar
LxMan1
Check the cables at the starter solenoid on the fenderwell and the cables at the battery. Sounds like you have a bad connection. Also check the ground cable where it is bolted to the engine.
Old Mar 4, 2007 | 01:22 AM
LOWBOY1979's Avatar
LOWBOY1979
Check the cables . Check your ground real close. And check for any melted fuse links near the solinoid. A melted fuse link will look just like a wire but will be a little thicker. When they melt it should be fairly obvious. It has to be one of those. It also sounds like the battery is a little low too. I would charge it for a while. Also if it was flooded I would pull the plugs and clean them, it will help to start it when you fix the starting problem. Good luck, Jesse.
Old Mar 4, 2007 | 01:27 AM
LxMan1's Avatar
LxMan1
12.53 Volts is fully charged.
Old Mar 4, 2007 | 01:48 AM
skunktruck's Avatar
skunktruck
i rebuilt all the cables... but in the morning ill recheack the ground thanks
Old Mar 4, 2007 | 03:15 AM
76 crew's Avatar
76 crew
use your voltmeter and check the battery then have someone turn the key to on, there should be a slight change in the voltage. then turn the key to start if the battery drops like 6 to 8 volts or more then you have a short somewhere, like battery or starter. even during cranking the batt shouldnt go below say 10.5 volts.
If you turn the key to on and your 12.5 reading doesnt change at all, not even a couple tenths of a volt then check fuses.
what kind of noise did you hear, a clicking?
check your grounds and fuses, if u still have no lights or anything, then follow the power with your meter. leave the black lead on the neg. batt. and use the red lead and start at the batt. u have 12v so follow the wire to the solenoid if u dont have 12 at the solenoid look at the cable, if u do go to the next component down the line if you dont have power look at the solenoid, etc.
Old Mar 4, 2007 | 05:21 AM
Talltruck's Avatar
Talltruck
And whatever you do, don't use bolt on battery terminals... They start off good when they're new but corrode fast and cause major resistance
Old Mar 4, 2007 | 10:35 AM
skunktruck's Avatar
skunktruck
i think it sounded like a ZZZZZZZZZZIIIIIIIIITTTTT sound, but it was a quick sound and not very load. when I rebuilt the wires I used 00 size wire you think this is to big for a truck. geuss i was thinking bigger is better he he.
Old Mar 4, 2007 | 12:10 PM
Mil1ion's Avatar
Mil1ion
Usually bigger is better.
Problem is The Battery is the HEART of any vehicle if that isn't up to snuff nothing else works.
Just because the battery reads 12+ volts doesn't mean it can crank a starter.
It's the cranking amperage that counts.
Sometimes batteries develop shorts inside themselves and become useless for starting.
Old Mar 4, 2007 | 12:24 PM
edward021070's Avatar
edward021070
try hooking jumpers to it or charger with the to start option if it start then you know that the battery is definitely the problem.
Old Mar 4, 2007 | 12:33 PM
skunktruck's Avatar
skunktruck
hey good idea, i think today i will use a load tester on it
Old Mar 4, 2007 | 03:17 PM
skunktruck's Avatar
skunktruck
hey great news it runs
took the main ground off the motor and cleaned it up. crazy thing ive had it in 3 ft of mud and pushing more and it worked fine. but the moument i put a newer/bigger one on a it wont work crazy truck.....but i love, keeps the tools from rusting i geuss.
thanks ya'll
Old Mar 4, 2007 | 09:35 PM
LOWBOY1979's Avatar
LOWBOY1979
12.5 volts is almost fully charged. 12.6 is fully charged. It may seem like it should make no differance but it does. 79crew is right on, you have to load thest the battery. and see how it recovers. when it recovers to 12.5 it is not to 100%. The reason I am picky about this is I had one burn me on a drivability problem once. I pulled my hair out looking for a cable or something wrong elswere. I began with just my voltmeter and it said 12.4, so after pulling apart things I finnaly load tested the battery. All it was, was a bad battery. Jesse.
Old Mar 4, 2007 | 10:18 PM
Mil1ion's Avatar
Mil1ion
Get yourself a battery hydrometer to check the specific gravity once in a while to check the disposition of each cell.
Old Mar 4, 2007 | 10:27 PM
LOWBOY1979's Avatar
LOWBOY1979
Good Idea but I have a VAT at work I use. A hydrometer is a great tool, I need to buy one . Jesse
