1978 - 1996 Big Bronco
Fan shroud adjustment
Old Aug 25, 2002 | 07:50 PM
Bob_VT's Avatar
Bob_VT
Old Aug 28, 2002 | 10:29 AM
scootin's Avatar
scootin
I tried to adjust the shroud around the fan assembly last night due to the actual fan coming in contact with the shroud. Still no luck. the fan contacts the shroud on the drivers side, which has no gap at all. the passenger side has well over an inch of gap. Is there a way to adjust it so there is more gap? It seems as though the only adjustment possible is up/down, and that is only to achieve a 1/4 - 1/2 inch adjustment, maybe?? I'm about to take a Dremel tool to it and just start slicing away the plastic - Yeah, I know the plastic is there for protection - but this noise is driving me nuts.
Old Aug 28, 2002 | 10:53 AM
Pioneer Ford's Avatar
Pioneer Ford
I would grind it down just enough to stop the blades from touching the shroud. Sounds like there might be something else wrong though. The fan shouldn't be rubbing anything. Check to make sure the shroud and radiator are seated properly in the frame rails.
Eric
Old Aug 28, 2002 | 08:09 PM
brokebronco's Avatar
brokebronco
Your body could have shifted due to worn mounts or it could be a bent frame.
BROKEBRONCO
84 Bronco 351HO/C-6/208/10.25 Rear/D44TTB Soon to have D60 Front/NP435
86 F250 351HO/C6/10.25 Soon to have a front axle and the ZF tranny
Old Aug 28, 2002 | 09:12 PM
jmackie's Avatar
jmackie
You MAY have a twisted frame. If the noise bugs you, take the fan
and shroud out and go with and electric fan. You will get a couple more horsepower by doing so.
Old Aug 28, 2002 | 11:42 PM
Riso79's Avatar
Riso79
I had the same problem with my Bronco. It was the motor mounts. the motor was falling down and causing the fan blade to touch the shroud.
Old Aug 29, 2002 | 01:45 PM
scootin's Avatar
scootin
Well, I figured out what caused the fan shroud to shift. the core support is rusted and has dropped slightly. NOT a great situation to be in. I was able to adjust the shroud the second time around so it doesn't come in contact with the fan blades. I'm wondering how big of a deal this really is (the core support), and what problems this could cause in the future. Ideas have been floating in my head to sell soon, while it is still worth some $$.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
