amp draw
Old Mar 3, 2007 | 08:19 PM
1979ford's Avatar
1979ford
amp draw
My battery keeps going down after a day of not driving it. When I use my multimeter to check amp draw do I use the ac or dc setting on it. Haven't done this in a while and need a refresher.
Old Mar 3, 2007 | 08:25 PM
Franklin2's Avatar
Franklin2
Neither one. You should have a amp or ma(milli-amp) setting. And you will also have an extra plug to move your probe and plug it in.
Not all meters have this feature. If yours doesn't, you can use a testlight.
Old Mar 3, 2007 | 08:44 PM
projectSHO89's Avatar
projectSHO89
More specifically, DC Amps
Use the highest possible range setting to avoid damaging your meter. Take steps to ensure that no unwanted power draws are activated while the meter is in circuit, ie, door or hood lamps, etc...
Failure to follow this will likely be fatal to the meter.
Steve
Old Mar 3, 2007 | 09:42 PM
kevin74656's Avatar
kevin74656
Steve
Yes, DC amps is the correct answer.
Most multimeters are fused to prevent damage from excessive current. However, it's possible that the fuse may have been replaced at some point in the past with a larger one, so Steve's warning is good advice.
Also, if your meter reads zero current, check the fuse. And be sure to connect it in series, as Franklin's illustration with the test light shows. I've seen lots of people connect an ammeter in parallel, and POOF goes the fuse!
oaks
18
Oct 12, 2014 09:53 AM
dutchford150
Feb 11, 2012 03:52 PM
therifleman556
18
Feb 19, 2010 09:06 PM
kooper909
Jul 9, 2006 09:51 AM
jboard
20
Mar 17, 2005 09:17 PM
