99 xlt a/c fan vent problem
Old Mar 3, 2007 | 05:42 PM
sinister_designs's Avatar
sinister_designs
Question 99 xlt a/c fan vent problem
Hi all
I have a strange problem with the fan vents in my 99 explorer, the a/c works fine but no matter what position you have the fan vents set to it will only come out the windscreen vent : (
Any ideas where to looks for faults?
thanks in advance
jason
Old Mar 3, 2007 | 06:24 PM
Steina's Avatar
Steina
CO River Rat
You have a vacuum problem; the air control defaults to defrost when there's no vacuum to operate the controls. Check under the dash and in the engine compartment for broken/loose/disconnected vacuum lines; also check the vacuum reservoir for leaks.
Welcome to FTE!!!
Steve
Old Mar 3, 2007 | 06:50 PM
sinister_designs
I have just finished checking all line's i can find nothing loose or off does it use engine vacumn or a electric one?
anyhelp welcome
jason
Old Mar 3, 2007 | 07:06 PM
Steina's Avatar
Steina
CO River Rat
IIRC, temperature is electrically operated and air control is vacuum operated. If you have vacuum to the control head, then it or an actuator may be bad.
Steve
Old Mar 10, 2007 | 10:49 PM
sinister_designs
Smile
I found the broken line in the engine bay under the fan box a real b!%ch of a place to get too but is fixed now
thanks for your help
Old Mar 11, 2007 | 12:27 AM
Steina's Avatar
Steina
CO River Rat
Of course; you didn't think it would break in an easy-to-get-to place, did you? Glad to hear you got 'er fixed.
Steve
