Brake Pressure Warning Switch?
Old Mar 3, 2007 | 09:45 AM
jackcassid's Avatar
jackcassid
Exclamation Brake Pressure Warning Switch?
I have looked at all of the online parts catalogs for stores here, and, I cannot find this part. Is their a more common name for this, and, where did you guys find yours? Please Help!
Old Mar 3, 2007 | 10:56 AM
Mil1ion's Avatar
Mil1ion
It's called a Brake Proportioning valve or Brake failure switch
Try this site
http://www.inlinetube.com/Prop%20Valves/
Old Mar 3, 2007 | 02:12 PM
riley3d's Avatar
riley3d
I used one of these power bleeders:
http://www.trackhaus.com/index.php?m...ex&cPath=77_65
not too expensive and it works great.
Old Mar 4, 2007 | 10:04 PM
ArcadeTom's Avatar
ArcadeTom
[QUOTE=Mil1ion]It's called a Brake Proportioning valve or Brake failure switch
Try this site
http://www.inlinetube.com/Prop%20Valves/[/QUOTE]
Mil1ion, I just got my Inline Tube P-valve for my '74 F-100. Mounts right up and I'm getting the adapters tomorrow. One big question I have is the pigtail. Original has two wires. The switch that came in the one from Inline has only one terminal. DOes anyone know what I need to do here?
Old Mar 4, 2007 | 10:22 PM
Mil1ion's Avatar
Mil1ion
I'll check the wiring diagram.
Edit:
From their web site.
Our proportioning valve has a dashboard warning light switch built-in (this is not a stop light switch). The warning light will indicate any loss of pressure, for example, a leaky wheel cylinder. We recommend you wire this light into your system. Any two-wire light socket will work. One wire goes to the accessory power and the other goes to the warning light.
Old Mar 4, 2007 | 11:08 PM
ArcadeTom's Avatar
ArcadeTom
The one I got only has one connection/
Old Mar 4, 2007 | 11:25 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C8AZ-2B264-A .. Switch, Brake Pressure Differential Warning Lamp / Fits: All 1968/79 F100/350 (& 1969/79 E100/350)
Screws into brake differential (proportioning) valve.
Failure: Minute cracks develop in threads, switch leaks, warning light comes on.
Old Mar 4, 2007 | 11:38 PM
Mil1ion's Avatar
Mil1ion
Tom, Do you have a pic ?
The OEM switch is just that: a set of contact points contact points to allow the current to continue to flow back to the light
Will the old switch not screw into the PPV ?
NDP has your switch. Page 2 of the brake section.
2B264 SWITCH, Brake Pressure Differential Warning Lamp
F1-350 67-79 Located on brake block (combo valve)........ 2B264-1 27.04
You don't want to know the price of the PPV's
Old Mar 5, 2007 | 12:25 PM
ArcadeTom's Avatar
ArcadeTom
OK, here is what I found out. Inline Tube says not to try using the stock switch. They did say to locate the "hot" wire from the ignition on the original pigtail and splice it to the one lead going to the new P-valve. The new one from Inline Tube is self grounding and that is why you only have to use the one wire. I did it and my brake light is working just like it is suposed to. Brakes are now working on ALL FOUR WHEELS again!!! WOO HOO!!!
Thanks for your help and I hope this helps someone else!
DJA1949
Apr 15, 2017 08:42 PM
Teutonics
Mar 23, 2017 10:26 AM
gluefactory
44
Dec 9, 2016 07:09 PM
chukar
Mar 19, 2016 10:53 PM
HKusp
Sep 16, 2015 04:01 PM
