I just picked up two trucks,a 84 f250 2x4, and a 76 f150 2x4.
the 84 has a 351 with a four speed,and the 76 has a 302 with an automatic.
I want top put the four speed in the 76 and ive got everything figured out except the clutch linkage. I just want to know if the linkage and pedal from the 84 will bolt into the 76 or will i have to modify things, or should i just source a pedal and linkage from a 73-79 truck. thanks and i hope i posted in the right place itried searching for this but found nothing.
I am sure you checked into it, but be sure that the flywheel has the correct counterbalance. I am not sure that the 76 302 and 84 351W have the same balance.
