Starter/tranny alignment probs.
Old Jun 30, 2007 | 02:38 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1986 351W 4V C6 = As original
D1ZZ-6375-A .. Flexplate ~ Marked: D1ZP-AB ~ 164 Teeth
E1AZ-11002-A .. Starter (Motorcraft SA-709-B) ~ Marked: E1AF-BA
D6PZ-11350-B .. Starter Drive (Motorcraft SD-302)
Old Oct 14, 2007 | 07:40 PM
cfrives3's Avatar
cfrives3
Just wondering if anyone found a solution other than the 10 tooth bendix gear? I still have not found one, and even though it sounds better, it's still eating starters. The last one (the new one when I bought the truck) lasted about 6 mo. with the bendix being replaced once. It tested good at the store, but the guys there know me, and believed me when I explained the problem so I got a new (rebuilt) one.
Wierdest thing though. We checked and my 300-6 calls for the same exact starter, but the good one I had laying around for my 6 would not work. Bolts line up perfectly, it is about 1/4 inch away from going through the index plate. Explain that to me could ya!
Old Oct 14, 2007 | 09:24 PM
toolman's Avatar
toolman
I put a Galaxie starter in mine. I figured I was eating a starter every 10 days or so, so what could it hurt ? They're nearly identical except the Galaxie starter has about 1/8" longer throw. That was in July and I haven't had a problem since.
-Scott
Old Mar 1, 2010 | 12:25 PM
cfrives3's Avatar
cfrives3
New motor, new tranny, same problem. I need to know where to order the ten tooth bendix from! HELP!
Old Mar 2, 2010 | 10:03 AM
cfrives3's Avatar
cfrives3
I found a 10 tooth bendix locally for $5. I bought two, as I am used to having two starters layng around for this truck. The diameter of the 10 tooth I found is 1.0963" I think is what he said. If anyone who has been a part of this thread is still watching, keep your fingers crossed for me. I went out to my other bronc intending to go pick up the two bendix- and the ignition switch has quit on it, so I have to go fix that first. (at least I hope that's what's wrong, but that will be a whole 'nother post)
Undone
Mar 15, 2013 01:27 PM
4mrdragoon
May 21, 2011 01:09 AM
tracye
Bronco II
Oct 31, 2003 03:47 PM
