1978 - 1996 Big Bronco
1986 Bronco - help
Old Aug 24, 2002 | 09:29 AM
muddogin400's Avatar
muddogin400
1986 Bronco - help
Old Aug 26, 2002 | 09:34 AM
phillips86's Avatar
phillips86
1986 Bronco - help
my daughter is driving a 86 Bronco and it has started just shutting off while she is driving - have replaced fuel filter and pump - still doing same thing - other night shut off while she was on freeway - let it sit a few minutes it will restart - no-one seems to know what is wrong since when it runs it runs great but until this is fixed it has to sit - any ideas???????
Old Aug 26, 2002 | 11:21 AM
Pilotrick's Avatar
Pilotrick
1986 Bronco - help
Don't remember the technical name for it but, have you tried the ignition module on the side of the dist. The have a bad habit of over-heating and causing the problem you mentioned. One word of advice though do not buy a cheap one from a discount parts store go to NAPA or Ford for it just MHO. Hope this helps and Good Luck,
Rick
86 302 EFI, bored 60 over, AOD,
Headman Headers, Flowmaster 40 series,
2 inch dual exhaust, MSD ignition
Old Sep 1, 2002 | 06:08 PM
Hwy Apostle's Avatar
Hwy Apostle
1986 Bronco - help
my 86 351w was doing the same thing would run great for about 10 miles then just die wait an hour and she start.
the problem was two fold the ignition module for one was bad.
the stater inside of distributer was also dryroughted and would over heat I beleive this caused the ignition mod to go out.
I opted to get a ne distributer alltogether its $50.00 at advanced with lifetime warenty were just the stater was $20.00 I didnt have the tools to pull the gear and set ring of to replace it thats why I went with full replacement. the ignition mod was $18.00 to replace hope this helps.
Old Sep 3, 2002 | 01:06 AM
WALLDOG18's Avatar
WALLDOG18
1986 Bronco - help
I HAD THE SAME PROBLEM AND IT TURNED OUT TO BE THE FUEL RELAY. IT IS LOCATED ON THE DRIVER SIDE FENDER JUST BELOW THE HOOD HINGE..
GOOD LUCK
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
