Fuel Drain O rings - help
I attempting to replace the famous O rings in the drain valve and have a question. The new O rings seems to be too large to fit the recess diameter in the valve. The old ones measure .487 (just under a 1/2") and fit nicely. But I can not press in the new ones using finger pressure. The new rings match the spec's I found on the grainger and mcmaster-carr website, measuring at .512 on the outside diameter..(the valve measures .484 inside the recess diameter.) I am surprised they are so hard and not pliable like the factory o rings.. Don't see how to make them work without pressing them in with my bench vise, which does not sound normal to me. Help
Fuel Drain Valve Viton 1/8" 1/4" 1/2" McMaster-Carr 9464K118 25/$5.46 202
http://www.7point3.com/OringChart.aspx
I recently went to Graingers and bought Viton o-rings for my water seperator on my 99.5. They were 25-rings for $5.17. They fit perfectly. It's been several weeks and all is fine, no more leaks. Others places I checked wanted 10-times the price. I dont have the numbers handy but it on another of my posts.
Originally Posted by J.D
Graingers 1BYU7 They went in alot easier then the old ones came out. Slight finger pressure for me.
jb10725
Dec 7, 2014 04:20 PM
Cougar54
42
Mar 23, 2014 01:41 PM
