Sponsored by: Auxito
new to me
Old Mar 2, 2007 | 07:12 PM
pace-harris's Avatar
pace-harris
new to me
i just picked up a 98 f 150 short bed 4x2 with a 4.2 v6 5 speed. I drove it about 6000 miles or so all highway to and from work.I got the oil changed ,tranny flushed,and fuel injecters cleaned.today. 2 starts and 40 miles later i went to start it and all i got was a click from the starter relay on the firewall. i changed that and while investigating the problem found that one of the pos. cables connecting to it (the one that is actually two wires with a rubber mold sepperating them)was corroded pretty bad so i replaced the tip of it.I thought that would fix it and the results are the same , just one click at the starter relay.the starter hasn't shown any signs of problems. but i did push start it to get it home,while driving the battery light did flicker a few times .does any have any suggestions?
Old Mar 2, 2007 | 07:43 PM
73f350sc's Avatar
73f350sc
SOunds like you have a dead battery to me....that clicking is the nosie that it will make letting you know that its dead same w/ the battery light haha..sounds like you replaced everything but the battery! Take it to an autozone or similar parts store and have it checked....its usually free plus you'll already have a core there if you need a new battery.
-Chris
Old Mar 2, 2007 | 08:52 PM
jimm66's Avatar
jimm66
If you have a meter check the battery voltage.
Old Mar 2, 2007 | 09:26 PM
pace-harris
Cool battery
the battery gauge is shopwing good voltage
Old Mar 2, 2007 | 09:30 PM
Racerguy's Avatar
Racerguy
Welcome to the forum pace-harris
If your battery checks out ok you should check for power down at the starter.
When you turn the key to the start position there should be 12V at the small terminal on the starter. This comes from the relay on the firewall.
There should be 12V at the big cable on the starter at all times. The cable ends corrode off sometimes.
Old Mar 2, 2007 | 09:38 PM
pace-harris
i have voltage there and i replaced one corroded end already
Old Mar 2, 2007 | 11:01 PM
73f350sc's Avatar
73f350sc
Never trust the dummy gauges in the truck especially when you have an electrical problem, thats why I said to have it checked on the tester. The guage could be reading good voltage but that doesnt mean that its accurate.
-Chris
Old Mar 3, 2007 | 10:17 AM
pace-harris
The problem is now solved.It ended up being the power wire that feeds from the starter to the battery.Corrosian must have got the best of it.I replaced the tips and still no juice,but when I replaced the wire itself I got juice.Thanks fellas!
Old Mar 3, 2007 | 10:18 AM
pace-harris
Now if I could just fix the door ajar light I would have no dummy lights on!Any suggestions?
Old Mar 3, 2007 | 10:32 AM
jimm66's Avatar
jimm66
Spray wd-40 in the door latches. Do a search on the subject. A lot of people have had the problem.
Old Mar 3, 2007 | 11:32 AM
3-RANGERS's Avatar
3-RANGERS
Hello pace-harris, I had exactly the same problem you did. Drove the truck to work and at the end of the day I got in it started it up and stalled it. I went to restart it and it wouldn't crank. Standard voltage checks showed ok but the amp check showed a problem. I used a set of jumper cables as a replacement power supply cable and the truck started right up. It cost me a days pay and a battery cable.-Joe
Old Mar 8, 2007 | 06:16 PM
pace-harris
well the door ajar light kind of stays off but not all the time,i used the wd-40 in both jams.but it seemed to work but the light is still occasionally comming on,like i said not all the time though ,its still an improvment , thanks again
Old Mar 17, 2007 | 11:15 AM
bigredneck47240's Avatar
bigredneck47240
try cleanin it and then sprayin it with pb blaster ive found it works better than wd-40. te wd in wd-40 stands for water displacement that is all it it is for pb blaster does what everyone thinks wd-40 should be used for sorry if i stepped on anyones toes
Old Mar 18, 2007 | 09:24 AM
pace-harris
hey thnks man ill try that because the wd 40 hasnt really worked that well,the door ajar light still comes on.
Old Mar 18, 2007 | 10:45 AM
skilife17's Avatar
skilife17
I second the PB-Blaster. I have used it on my door latches and it works great. When I first bought the truck it was fine but then last summer the dang light started staying on. I didn't find this site until after I replaced the switch . I try to spray mine at least every few months.
