1978 - 1996 Big Bronco
Need help with Noise
Old Jul 14, 2002 | 04:19 PM
91Bronco's Avatar
91Bronco
I have a 91 with a 302. It has a Jasper Rebuild with about 30K on it. I hear a noise when i accelerate that sounds like an exhaust leak, but i can't hear it when the truck is in park. When in park it sounds perfect. If it was an exhaust leak wouldn't i hear it when the truck was in park and i reved the gas? Any help would be appriciated.
Old Jul 14, 2002 | 07:26 PM
Techols's Avatar
Techols
EGR leak, maybe; had this happen to me. Could be a trans whine?
Old Jul 14, 2002 | 08:39 PM
91Bronco's Avatar
91Bronco
Thanks, I'll check out the EGR. Definitely not a trans noise.
Old Jul 14, 2002 | 10:26 PM
Jermafenser's Avatar
Jermafenser
WHERE is the noise? That will help.
Old Sep 4, 2002 | 07:02 PM
massbronco's Avatar
massbronco
MY SON IS CONSIDERING A JASPER REBUILT FOR HIS 90 BRONCO 302. ALL IN ALL, HAVE YOU BEEN SATISFIED WITH THE ENGINE QUALITY? I ASSUME YOU DID A LONG BLOCK INSTALL? SORRY, CAN'T HELP WITH YOUR PROBLEM, THANKS IN ADVANCE FOR THE INPUT ON THE REBUILT.
Old Sep 5, 2002 | 12:07 PM
dustylollis's Avatar
dustylollis
make sure your plugs from the engine are mapped to the correct fittings in the distributor cap. i had the same problem a few months back on the bronco i bought. it sounded fine idling...no problem. but when i accelerated it sounded like an exhaust leak. it finally hit me what it was. i popped the hood with my chilton's manual and confirmed my suspicion. the person or shop who had worked on the engine had used the mapping for a 5.0...mine is a 5.8. i switched the wires around and immediate "relief" bellowed from under the hood.
just a thought!!
Old Sep 5, 2002 | 12:30 PM
yosemite's Avatar
yosemite
