1978 - 1996 Big Bronco
Need info on the 302
Old 09-06-2002, 11:50 PM
ryanguglich's Avatar
ryanguglich
ryanguglich is offline
My truck has a 302 in it right now that I've never heard running. I did a compression test on it and found an average of 110psi in all the working clyinders. 1 had a stuck exhaust valve and 1 had a stuck intake (they bent the pushrods) I got new pushrods gaskets etc.. While I had the heads off I pocket ported them I didn't match the ports to the intake because it's the stock 2 Barrel and I want an alum. 4 barrel. The valves were lapped and seemed to seal better.
I have 2 questions.
1) when I get the heads, intake and everything put together.. what's a reasonable psi to not rebuild the motor ( I know they should all be within 10%)
2) I also (after putting on my heads) got a set of stock iron heads off a 79 302. the valves have alot more meat to them and stick out of the seats more than mine, also the ports are atleast 125% larger than mine, they also have stud mounted rocker arms (mine have pedestal)
would these heads be a better choice? were they made differently then?
(any other parts off the 79 I should be looking for?)
thanks you.
Ryan
1981 Bronco 302 auto no mods.
Old 09-07-2002, 01:57 AM
heybrent's Avatar
heybrent
heybrent is offline
bigbadford78
05-19-2010 12:07 AM
shephard199
01-14-2010 09:20 PM
rmalottwtes30
10-09-2007 12:05 PM
X-1
03-10-2004 12:27 AM
ryanguglich
09-15-2002 10:44 PM
Quick Reply: Need info on the 302
