gauge install complete!
Old Mar 3, 2007 | 05:10 PM
m350's Avatar
m350
Not really sure southbound,,gonna have to do some shopping,,on the quick disconnect ,But I sure do like the looks of those aluminum caps,,by the way,,what kind of oil pressure #'s are you getting on the 6.0' ??
Old Mar 4, 2007 | 08:04 AM
Diesel_D's Avatar
Diesel_D
I think the looks are worth the extra effort. Look awesome! I just meant that the filter removal tool or socket whichever is used wont fit over the gauges and or sending unit, sure wouldnt want to use a crescent or pipe wrench on those babies. As far as quick disconnects I believe they make them for 1/8" npt same as the ones for 1/4" npt air hose, but you would have to use a deep well socket thats for sure. Think I am gonna get me some of those caps they are cool.
one other thing to think about is height. Would you have enough clearance between cap top with quick disconnect/Gauge and the hood? just curious.
Old Mar 4, 2007 | 09:33 AM
southbound35west's Avatar
southbound35west
the oil pressure readings fluctuate alot, when i start it up and it been sitting for 10 hours or more, the oil psi goes up to 80psi at an idle, it will go up to 100 psi when taking off when the rpms get up, but after i drive it for 5 minutes or so, the oil psi will come down to 30 psi at an idle and go up to 60-80psi when driving after it has warmed up..................................Diesel_D, i was worried about hood clearance the way the fuel gauge is setup now, it just barely clears, but if i had a quick disconnect to install i could take out a coupling and a nipple to shorten it a little to make room for the dissconnect.
Old Mar 4, 2007 | 09:34 AM
exiled's Avatar
exiled
Southbound thats nodoubt some fine work. I noticed that you have your egr still hooked up. Had you ever disconneted it? Do you ever clean it out? I ask cause i see you have so serious modds and it's sorta my understanding from my research that most guys at your level of modding has deleted the egr. I'm undesided on the subject. I read the 'whole' in the tech files on the subject and out all {what 170 ?}the posts i cant find heads or tails as to weither it actualy does anything. I was suprised to see your's still hooked up with you having deleted your cats and muffler.
Yea theres an 1/8" thread on the quick connect.
Old Mar 4, 2007 | 02:27 PM
southbound35west
i have never unplugged the egr, i have thought about trying it, but was wandering if there r any negative effects of unplugging this device and what r the positive effects? i have never cleaned it either, i too would like to find out more on this subject,,,,,,,,,,i hope that i have not effected my warranty due to the mods i have done to this 2006 truck.....................where did you find the 1/8 quick connect at? will it work with fluid?
Old Mar 4, 2007 | 09:51 PM
Diesel_D's Avatar
Diesel_D
This place here says they have quick connects for fluid use
TOMCO Quick Couplers
Says they carry 1/8” to 1 ½” brass (under straight thru fittings)
<O</O
http://www.tomcoquickcouplers.com/product/straightThrough/st/index.html
<O</O
<Ohttp://www.tomcoquickcouplers.com/pdf/pg34-35.pdf
TOMCO website "Straight-Through or “Full Flow” couplers are non-valved and are usually applied in liquid systems needing maximum flow with no restrictions. Some typical applications are in chemical processing, pressure wash, plastic mold coolant lines, on water manifolds, food processing and other liquid handling applications where shut-offs are not needed and full flow is advantageous"
Dont know anything about them except for what I read on a web search
Whats kinda cool is on that PDF they show they have dust caps which would look real good when not using the gauges for any reason.
</O
Old Mar 4, 2007 | 09:54 PM
southbound35west
thanks for the info dieselD.
Old Mar 16, 2007 | 11:18 PM
southbound35west
Thumbs up quick connects
i think i will try a set of those 1/8th inch quick connects for my fuel psi guage and my oil psi sensor, on my filter caps, this would make filter changes alot faster and easier.
Old Mar 16, 2007 | 11:53 PM
exiled's Avatar
exiled
Brother i am sorry. I have somehow missed your response to this post. I found the connectors at ace hardware. Sure they work for fluid. The kind i use is used with high pressure washers like 10ks, 20ks. Of course i use them on my airhoses. I like them better cause they are alittle bigger and sure are easier to couple together for me.
Old Mar 17, 2007 | 12:49 AM
mrholmes's Avatar
mrholmes
how much did all this cost you..i like it.. i want it...
Old Mar 17, 2007 | 09:28 AM
southbound35west
Talking costs for these mods
the aluminum oil and fuel filter caps with an 0-100psi oil filled fuel guage will cost u aorund $160-175...............the intake elbow was $150................the sensors that r plumbed into the caps came with my autometer cobalt2 guage package which was $650.......................other pics of these r in my gallery.
<TABLE width=460 bgColor=#000000 border=0><TBODY><TR><TD><TABLE width=460 bgColor=#ffffff border=0><TBODY><TR><TD colSpan=2></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
Old Mar 18, 2007 | 03:52 AM
Diesel_D's Avatar
Diesel_D
Hey South Bound I notice you have the Black plastic cac tube connected to your elbow. They have those crappy hose clamps on them.Well actually looking at your pictures your hose clamp looks to be more heavy duty then the one that was on my truck. Well anyway my cac tube kept blowing off, so I just got an aluminum cac tube with much better clamps put on at the dealer (they said it was a recall). I dont know if you have had the cac tube blowing off problem but if you tow up any mountains you probably will. instead of just one hose clamp the new ones have a rubber sleeve fitted between the elbow and the cac tube with 2 heavier clamps on them.
Old Mar 18, 2007 | 07:13 AM
  #28
WishIhada7.3's Avatar
WishIhada7.3
as for my exp on the egr unplugg...I did it for about a 3 mile test run..did notice quicker spool up by about 2-300rpms once up to opp temps first WOT run seemed like it was missing its ***...mbrp seemed much calmer...2nd wot run watching my boost guage...i was between 25-27psi....couldnt get any higher than that...my norm is 32-33psi...so the loss of bost wasnt worth the quicker spool i plugged that sucker back in..
Old Mar 18, 2007 | 01:55 PM
  #29
southbound35west
i think i will leave my egr plugged in also, for now........
Old Mar 19, 2007 | 05:27 PM
  #30
southbound35west
Thumbs down recall
Diesel D, i called the ford dealer today and they told me there are no recalls on the 2006's as of right now, so i guess that is only for the 2003-2004 trucks, but it was worth a try, i much rather have the metal cac tubes with the rubber couplers than the plastic ones i have now.....................
