Sponsored by: Auxito
How big??
Old Mar 2, 2007 | 10:37 AM
wezol5484's Avatar
wezol5484
How big??
Will 305's fit on my 97 F150 4x4?? I was told they would but I would have to crank the torsion bars. I want to make sure.
A friend of mine has a set of tires for $400. They are 305's, goodyear wranglers and they still even have the blue dye on them. They look freaking good.
I really want them
Old Mar 2, 2007 | 05:38 PM
wendell borror's Avatar
wendell borror
I've heard you can run up to a 35" tire on the newer f-150's, this is hearsay since I haven't personally done it. On my ranger I can run 32" tires and 33" with the t-bars cranked, so it doesn't sound unreasonable. I do have 32's on my ranger with the t-bars cranked and know 33's would fit, just not on my stock rims like the 32's, so this is not hearsay, this I've done. Sorry I couldn't be more help.
Old Mar 2, 2007 | 08:02 PM
Code3's Avatar
Code3
Look here:
https://www.ford-trucks.com/forums/2...ize-chart.html
Old Mar 2, 2007 | 08:25 PM
wendell borror
Well if thats accurate, then by cranking your torsion bars, the 305's should squeeze under there.
Old Mar 3, 2007 | 09:25 AM
Beast12's Avatar
Beast12
Thread moved to 1997-2003 F-150 forum.
-Matt
Old Mar 3, 2007 | 11:59 AM
tinman67's Avatar
tinman67
Goodyear Wrangler
I have a set of Goodyear Wrangler MT 285s on my 97 with no mods. Looks like ther may be a bit more room but 305s may rub under some conditions. I am planning a 4 inch lift B4 I get any bigger tires. I love the Goodyears.
Old Mar 3, 2007 | 12:19 PM
galaxie641's Avatar
galaxie641
Anything larger than 285/295's will rub both at a full turn and when bottomed out on a 4wd '97-'03 F150.
