1978 - 1996 Big Bronco
Erratic Tachometer
Old Sep 7, 2002 | 04:33 AM
RAzaRazor's Avatar
RAzaRazor
Erratic Tachometer
My tachometer has started acting funny in the last few days. I will be driving along, and it will suddenly indicate ~800-1200 RPM more than then engine is doing. There is no change in the actual engine speed.
Sometimes, it's a quick blip, and sometimes it continues to read wrong for a while.
Any ideas why it would be doing this, and what can be done to fix it?
The truck is a 93 with the 5.8L, and 168K miles. I was planning on replacing the coil with an MSD so I can increase the gap on my plugs. Would doing this possibly fix the problem?
Thanks!!
Old Sep 7, 2002 | 09:03 AM
restorit's Avatar
restorit
Erratic Tachometer
If the tach, itself, isn't going bad (and assuming the associated wiring is okay), I'd keep a very close eye on your ignition system. Many times, ignition components going bad can show up in bouncing / erratic tach readings. I've seen this, myself, in: bad spark plug wires, bad stator/coil, bad ignition module, and in a distributor with shot bushings. With 168K miles, you may check for bad connections and then consider what components may be due for replacement, anyway (cap, rotor, wires?). Just a couple of thoughts.
Old Sep 7, 2002 | 10:16 AM
mudder trucker's Avatar
mudder trucker
Erratic Tachometer
aurgathor
Mar 30, 2015 05:07 PM
miashley150
13
Aug 22, 2013 11:34 AM
Tom D
Aug 17, 2012 11:48 AM
allerickb
Oct 15, 2009 07:36 AM
WetDog
2004 - 2008 F150
Nov 27, 2006 04:44 PM
