1997 Explorer windshield wipers
Old Mar 2, 2007 | 12:56 AM
doncj22's Avatar
doncj22
I have a 1997 Explorer and the windshield wipers are not working. I've changed the motor and the switches click when I turn on the wipers but...nothing happens. I've actually switched out the switches in different locations and everything else still works so I don't think that's it. Does anyone have any ideas, suggestions, or similar scenarios that they have had success fixing this problem?
Thanks
Doncj22
Old Mar 2, 2007 | 03:46 AM
87 XLT's Avatar
87 XLT
The first thing that I would do is test the multifunction switch. If I could post the pics for how to do this I would.
By "switches" do you mean the relays under the hood?
Old Mar 2, 2007 | 01:05 PM
doncj22's Avatar
doncj22
Yes, that is what I meant the relays, for some reason I hand a brain block and couldn't remember what to call them. I've moved them around and they work with other functions still.
Now where is the malfunction switch? I'm not sure if I know where that is even if I saw it.
Thank you for your help.
doncj22
Old Mar 2, 2007 | 01:18 PM
cwix's Avatar
cwix
The multifunction switch is the actual switch on the steering wheel... the blinkers, brights, windshield wipers, spray...
You remove the cover and then its easy to remove the switch... Ive heard of some people cleaning them out, and cleaning the electrical conector.. if that doesnt work, the switch isnt too expensive at the parts store
Old Mar 2, 2007 | 03:55 PM
doncj22's Avatar
doncj22
Great, thank you.
doncj22
Old Mar 2, 2007 | 04:39 PM
fmrplt's Avatar
fmrplt
I had a weird problem with my wipers too. If you're hearing the clicking when you turn the switch on then try the relays. Swap the run/park relay with the hi/low one and see what happens. I ended up also using the horn relay because I couldn't find the right relay at the parts store. Everything is working fine now, even the horn. One of my relays may have been sticking. But I'm not looking a gift horse in the mouth.
Old Mar 2, 2007 | 06:59 PM
doncj22's Avatar
doncj22
I tried that as well, (funny my horn didn't work for awhile and it does now), anyway I'll fool around with the relays a little more. I just hope it doesn't rain soon. If I can't get this wiper issue fixed I'll probably have to take it to an electrical shop.
Thanks for the info...
doncj22
Old Mar 2, 2007 | 07:26 PM
87 XLT's Avatar
87 XLT
Try removing interior fuse 25 for a minute & reinstall it. If the "Central timer module/CTM/Generic electronic module/GEM just needs a good dope slap, that might get the wipers going again.
If not & if you have a VOM & want to test the multifunction switch, post back & i can tell you how to hook up your ohm meter & test it.
Old Mar 4, 2007 | 02:59 PM
hagg26's Avatar
hagg26
87XLT I would like to know how to test the multifunctionswitch with an ohm-meter
Old Mar 4, 2007 | 04:27 PM
87 XLT's Avatar
87 XLT
hagg26, I have the factory wiring diagrams for my 87 Ranger/95 Taurus/97 Explorer.
If you own one of those 3 vehicles, I just need to know which part of the switch you want to test.
Is it the wiper, headlight, turn signal or emergecy flasher circuit that you want to test??
Old Mar 4, 2007 | 06:45 PM
doncj22's Avatar
doncj22
Well, I don't have an ohm meter, I guess I'll have to get one. I'm curious about how to test the wiper swithch just as hagg26 is.
Thanks,
Old Mar 5, 2007 | 12:13 AM
87 XLT's Avatar
87 XLT
As they say a picture is worth a thousand words. Wish I could post a pic. According to the wiring diarams each pin of the multifunction is numbered, so instead of looking at a pic, you can find the correct pin numbers on the switch
For a 1997 Explorer:
Washer switch circuit:
Connect your VOM to pins 590 & 993.
"With wiper switch OFF, push washer switch in & read a closed circuit/zero ohms.
Release washer switch & read 103K ohms.
Wiper switch circuit: Connect VOM to pins 685 & 993.
Switch off read 47K ohms
Switch on intermitant read 11K ohms
Switch on low read 4K ohms
Switch on Hi read closed circuit/zero ohms.
Interval switch: Connect VOM to pins 590 & 993
"Rotate control toward OFF Ohmeter will show smoothly increasing resistance from 3K ohms to 103K ohms max."
Thats all there is to it.
The "Central timer module (CTM)/ generic electronic module (GEM" (I love saying that)
reacts to these different inputs by grounding the leads from the wiper relays to turn on the wipers/washer.
Old Mar 9, 2007 | 06:35 PM
doncj22's Avatar
doncj22
Thumbs up
Everyone...thank you for your help I got it fixed. I replaced the wiper switch (wipers, turn signals, high beams, etc...) and the relays for the wipers and it fixed the problem and everything is working again.
